Old Sat, Apr-21-2018, 03:58:26 PM   #41
rovert604
rovert604's Avatar
Default Subframe surprise
The trunk panel is not structural. I had that too. When doing Vincebar that had to come off. It carries no load acccept to create a floor for the trunk. What you’re seeing is the sound insulation cracked.
It is much more probable that you will have upper mount cracks though. Underneath you need to clean a lot more to see other cracks. When you can see bare metal after using a grinder, you’ll see everything nice and clear.
--Trevor in 604--
Vancouver, BC, Canada
Jump to top rovert604 is online now   Reply With Quote
Old Sat, Apr-21-2018, 04:29:16 PM   #42
Kdubski
Kdubski's Avatar
Reputation: 0 Kdubski is on a distinguished road
Default Re: Subframe surprise
It's going to be a good time for sure. The crack near the mount is plenty to convince me to get to work. I'm going to speak with a local race shop to get their opinion on what to do - as they specialize in E36 + E46 M3's.
Until I start work - I'm loading up on goodies (camber arms, solid bushings, etc)
Jump to top Kdubski is offline   Reply With Quote
Old Wed, Aug-29-2018, 05:44:32 PM   #43
Kdubski
Kdubski's Avatar
UPDATE:
Took out subframe today. For those following here are the cracks on rear left & front right mounts. Many have told me these are normal and about average for age (101k).
I am welding them up this week with turner plates, powerflex race bushings & a whole lot of other goodies.
Old Wed, Aug-29-2018, 06:36:42 PM   #44
Texaz3
Sounds like a good plan. Good luck.
Discussing Subframe surprise in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
