Old Fri, Mar-30-2018, 10:18:34 PM   #1
michaelkapanzhi
Reputation: 0 michaelkapanzhi is on a distinguished road
Default Car dies going from high rpms to idle rpm
So ever since I got my car (2005 M3) in 2016 I've had this issue with it. If I'm at cruising speed in gear and press in the clutch long enough for the RPMs to drop down to idle, the car will die. This is only an issue if i decide to put it into neutral before I come to a stop. Driving normally, (leaving it in gear until I come to a stop or downshifting to a stop) this doesn't happen. Since this doesn't really effect my everyday driving I've just ignored it.
Does anyone know what may be the cause of this?
Jump to top michaelkapanzhi is offline   Reply With Quote
Old Fri, Mar-30-2018, 10:31:42 PM   #2
e46Dan
Reputation: 0 e46Dan is on a distinguished road
Default Re: Car dies going from high rpms to idle rpm
Could be a vacuum leak. You might try a smoke test.
Jump to top e46Dan is offline   Reply With Quote
Old Sat, Mar-31-2018, 12:14:14 AM   #3
rovert604
rovert604's Avatar
Mostly an intake vacuum leak. I had that exact problem. I installed an intake and I didn’t put everything back together tightly. It was so little of a crack open but enough to cause stalls.
Also if you have an intake you want to use the mesh filter inside the OEM box to put in between the cone filter and the intake pipe before the MAF.
--Trevor in 604--
Vancouver, BC, Canada
Jump to top rovert604 is online now   Reply With Quote
Old Sat, Mar-31-2018, 03:32:05 AM   #4
michaelkapanzhi
I actually purchased the car with a K&N intake already installed and don't have any of the OEM parts. I'll check for a vacuum leak next.
Old Sat, Mar-31-2018, 05:10:05 AM   #5
rovert604
rovert604's Avatar
Just undo everything from the intake plenum and put it back together nice and snug. I really didn’t know where my leak was until I did that during some maintenance. Then I was pleasantly surprised when my engine stopped doing exactly what yours is doing.
--Trevor in 604--
Old Mon, Apr-02-2018, 05:35:33 PM   #6
cozmo kraemer
cozmo kraemer's Avatar
Reputation: 0 cozmo kraemer is on a distinguished road
You need the stock MAF screen to install in the K&N intake. That helps with this problem, but doesn't completely solve it. To solve it, get rid of the K&N and go back to a stock intake box.
2004 E46M3 - BBS RGR - RE11, BMW Motorsport 3.91, Eibach Pro Street S Coilovers (500/600), GC plates, Swaintech coated SSV1 Headers/SS catted/resonated section 1, Karbonious CSL intake, Shrick 280/272 cams, CSL DME Conversion, TTFS tune, OEM CSL front and rear seats
2010 - X5 4.8 Msport - the boring daily driver
My Journal
Jump to top cozmo kraemer is online now   Reply With Quote
Old Tue, Apr-03-2018, 12:38:43 AM   #7
ctres
ctres's Avatar
Reputation: 0 ctres is on a distinguished road
As others said, the K&N intake is your problem. A stock box will fix the issue. On mine the problem also went away when I taped off the duct that pulls air from the kidney grills.
Jump to top ctres is offline   Reply With Quote
Old Tue, Apr-03-2018, 02:31:35 AM   #8
rovert604
rovert604's Avatar
Wow I’ve never had a problem with mine once I had leaks sorted. It’s perfectly fine and the induction sound I get creates a great emotion when at WOT.
--Trevor in 604--
Discussing Car dies going from high rpms to idle rpm in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
