Old Sat, Jan-25-2020, 05:04:51 PM   #1
Kieffer87
Reputation: 0 Kieffer87 is on a distinguished road
Default Crank Sprocket Index Pin
TL;DR: I sheared off the index pin on my crank sprocket, do I need to replace the crank sprocket?
I pulled off the front lower timing cover to replace the oil pump tensioner and front main seal. I noticed when I was putting the harmonic balancer back on that the index pin which aligns the crank sprocket and harmonic balancer had sheared off. I was going to put it back on anyways because with 4 bolts (#8 in link below), I can simply ensure the balancer is aligned with where the pin would have gone. Then I saw https://imgur.com/a/BHtj3eY and they seem to indicate the index pin is essential for timing.
https://www.realoem.com/bmw/enUS/sho...diagId=11_2997
What am I missing? if the 4 long bolts connect the balancer -> sprocket -> crank how is it possible the little soft metal index pin is essential for timing? I've not removed the timing chains nor the sprocket so timing should still be set right?
2003 M3 Alpine/Cinnamon
APEX ARC-8 18x9.5 ET35 wrapped in 265/35 PSS
TCKline D/A Coilovers (550F/600R) W/Monoball RSM, H&R Adjustable Sway Bars
Fabspeed Headers, UUC Corsa Exhuast, CPI RASP-X
Rogue Power Pullies, AA Tune, SS Lines, ZHP Steering Rack
Jump to top Kieffer87 is offline   Reply With Quote
Old Sat, Jan-25-2020, 05:36:32 PM   #2
heinzboehmer
heinzboehmer's Avatar
Reputation: 0 heinzboehmer is on a distinguished road
Default Re: Crank Sprocket Index Pin
I think that pin is there to indicate how the balancer should be installed. The orientation is probably essential, but not the pin itself. Mine was sheared as well and I just reinstalled it using the sheared pin as a visual aid. No problems in 15k miles or so.
Jump to top heinzboehmer is offline   Reply With Quote
Old Sat, Jan-25-2020, 05:38:58 PM   #3
Kieffer87
Glad to hear, that's the answer I was looking for
Old Sun, Jan-26-2020, 05:30:00 PM   #4
bigjae1976
You just need to orient it correctly otherwise the TDC mark on the damper will be at least 90 degrees off when you time the motor.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Mon, Jan-27-2020, 09:11:21 PM   #5
sapote
On the subject of crank sprocket, the main seal stopped the oil leak around the sprocket outside diameter, but what stops the oil leaking via the 5 mounting bolts? I don't see any o-ring between the sprocket and the crank to seal off this path. Any ideas?
Discussing Crank Sprocket Index Pin in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
