Old Thu, Jan-23-2020, 10:24:36 PM   #11
Default Re: Will not start on the first attempt only after it has been sitting for hours
Originally Posted by Newswartz View Post
I had the same issue (no codes) and was convinced it was fuel pressure. I changed the fuel pump, fuel pressure regulator, fuel filter, injectors, maf, intake timing sensor, exhaust timing sensor. Turned out to be my smaller mini battery. Went back to the oem battery no issues. The smaller battery never had any issues and cranked strong and had enough juice to start every time. My assumption is the smaller battery didnt give the fuel pump enough voltage to properly prime and bring the pressure all the way up on the first try.
That doesn't sound right.
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · zero options · ~3100lbs · JOURNAL
Evolve-R Alpha N · Evolve CF CSL Airbox · Eventuri Scoop · Supersprint V1 stepped 2.5" · SS V1 2.5" sect 1 · OE sect 2 · SCZA 2.5" sect 3 · Besian · RE pulleys/fan delete · CSL battery
Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs · Hotchkis front sway · F & R strut bars · TMS camber & subframe plates · Eibach alu rear camber arms · RE trans mounts · AKG poly subf/diff 95a · SDW RTAB · OE weighted ///M knob + ZHP alcantara boot + UUC DSSR
OE CSL trunk · Cobra Nogaros + BK + manual OE bases · TMS black pedals · Sportline 8S 18"x 8.5/9.5" · MPSS 245/275 · APEX 75mm Studs · Brembo 996 4 pot 345mm CSL + Textar & 328mm CSL + ATE · ZHP "712" rack
DD: 2012 TiAg/Blk 128i · N52 · ULEV · Slicktop · 6MT · manual heated seats
Eibach springs & sways · Koni STR.T · Whiteline SF bushes · Dinan camber plates · M3 FCAs
Old Thu, Jan-23-2020, 10:26:20 PM   #12
That doesn't sound right. All car batteries, if in good health, give out 12v-14v. Maybe the battery was low or something, but running a mini/csl battery is not a problem. Csls aren't having issues with their fuel pumps & battery are they?
Old Thu, Jan-23-2020, 11:16:28 PM   #13
Jk715
Reputation: 0 Jk715 is on a distinguished road
Had the same symptoms. It was my battery on its way out. I was at the point where if i didn’t trickle charge, car wouldn’t start after sitting for 2-3 days. I tested fine for parasitic draw and voltage showed 12.6-12.8v when i switched it out.
No problems starting on first crank after the new battery.
Jump to top Jk715 is offline   Reply With Quote
Discussing Will not start on the first attempt only after it has been sitting for hours in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
