Old Wed, Jan-22-2020, 09:21:12 PM   #11
digger
Default Re: VAC rod bearings 80 K miles review
for a long time I've had a sneaking suspicion that people with worn bearings weren't waiting for the oil to get to temp before beating on it. this goes a fair way to confirming that. With thick oil its just so much more critical. the bearings show who's been telling porkies
what did the plastigauge say when you installed them 80k ago?
1996 e36 M3 Evo
Jump to top digger is online now   Reply With Quote
Old Wed, Jan-22-2020, 09:48:35 PM   #12
Aeko
Aeko's Avatar
Reputation: 0 Aeko is on a distinguished road
Poor fuel is a huge contributor to bearing wear (91 octane states especially).
Because of detonation or something else?
If you wanna make REAL donuts, run Crisco in your diff.
Jump to top Aeko is offline   Reply With Quote
Old Wed, Jan-22-2020, 09:49:15 PM   #13
HassanEido
HassanEido's Avatar
Lebanon
I run mostly 93,sometimes 94.
@digger I agree. When I put an oil pressure gauge on and tested my oil pressure and vanos oil pressure at cold starts, it was terrifying to see how high the pressure goes up(as a result of a more viscous oil when cold) resulting in poor flow and high pressures. So I just never rev it before its all warmed up for fear of bearing wear and blown vanos oil lines, which can have 250 bars at 2.5k rpm when it's cold . It's only a 5 to 10 minute drive before its happy and I just give it the beans afterwards.
Sent from my JKM-LX1 using Tapatalk
PM for performance tune requests
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Wed, Jan-22-2020, 10:18:55 PM   #14
lemoose
lemoose's Avatar
Reputation: 0 lemoose is on a distinguished road
good to hear as I've been running these for over a year and was on the fence between VAC and WPC
I'd go with acl or bmw tbh
despite what I assume was a positive experience?
Jump to top lemoose is offline   Reply With Quote
Old Wed, Jan-22-2020, 10:32:53 PM   #15
HassanEido
HassanEido's Avatar
Lebanon
Between wpc and vac I'd choose vac. I'm not a fan of hardened surfaces on bearings. But I think the coating wasn't necessary on the vac's either. Stock bearings routinely live over 100k miles. Acl are a genuine upgrade at a lower cost so I went that way. But if you wanna spend the extra money on vac's coated bearings then why not if I knew those bearings were gonna look that good I would've kept them lol. They were in perfect like new condition. Too late now
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Thu, Jan-23-2020, 12:11:13 AM   #16
icecream
Registered Apples
icecream's Avatar
Why not go VAC Calico coated since those still look brand new? Is it jist cause you'd replace them anyway?
Crazy though the condition of those. Seems the softer someone drives these the more issues they have, as if the car was designed for hard use.....
Old Thu, Jan-23-2020, 01:34:18 AM   #17
GeorgeH
BMW Fan
Reputation: 0 GeorgeH is on a distinguished road
Hassan, thanks for posting these findings, great data!
Current Garage... '00 R11S, '09 HP2S, '12 R12GSA, '00 Gray 332iT, '00 Black 323iT (wife's), '02 Alpine 325iT (Eileen, Track Wagon), '02 Japan Rot 325iT, '04 Gray 325iT, '04 IR ZHP Sedan
Instagram @ HillPerformanceBimmers
Email to George@HillPerformance.com
Jump to top GeorgeH is offline   Reply With Quote
Old Thu, Jan-23-2020, 04:11:44 AM   #18
Syfon
Reputation: 0 Syfon is on a distinguished road
I'm sure this is a massive issue with a lot of people who don't or didn't know about making sure the oil is warm enough before belting the piss out of it. But surely it can't be the one big mitigating factor to avoiding a spun bearing.
Every single time I drove (I say drove as my M3 has a spun bearing) my M3, I ALWAYS let the oil hit at least 75c before venturing above ~3k rpm. Oil changes were done every ~5,000km. Bearings were factory, and then at 93k km, she spun a bearing (****load of copper in the oil filter).
Engine/box are out of the car. Will pull of the sump and inspect bearings + crank journals when I get the time over the next month or so. I'll post some pic when I do it too...
Jump to top Syfon is offline   Reply With Quote
Old Thu, Jan-23-2020, 05:39:41 AM   #19
HassanEido
HassanEido's Avatar
Lebanon
I like to try stuff so I'm trying the acls out this time . But I got the acls mainly as a cost saving measure and they sure look good on paper,so we'll see I guess. I sure would recommend vac to anyone now that I know. My short oci might have something to do with it too I guess. I also never drive it in the lower rpm range once it's up to temp. Just like you would drive a sport bike in the mid range of the rpms, always between 2500 to 4000 rpm where it feels happiest when I'm at part throttle, and I don't go wot under 4k too often either.
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Fri, Jan-24-2020, 08:20:31 PM   #20
.'s Avatar
Reputation: 0 . is on a distinguished road
I use to drive like this then I got this thing called a Hassan tune that gained me a bunch more low end power and I love to romp on it starting at 2k on up, its so addicting. After it’s fully up to temp of course
2001 E46 M3 - Slicktop Manual Coupe - Alpine White on Imola Red
Engine: Karbonius CSL airbox, Lang Racing stage 2.5 head, Schrick 288/280 cams & followers, Lang Racing rod journal widening kit w/ CP 12:1 87.5mm pistons & Carrillo rods, Kassel CSL DME & MAP conversion, 36lb injectors, Hassan tuned, APE Flex fuel kit, TMS Power Pulleys, SS V1 stepped headers & catless section 1, SS 2.5” twin-piped resonated section 2, SGT scza section 3.
Drivetrain: DKM Stage 2 Clutch, E60 Shifter, RE trans mounts, Motorsport 4.10 R&P, Revshift 80A diff bushings.
Suspension/Brakes: Ohlins 3DM “track day” kit, RE strut bar, AKG RSM's, UUC front sway bar, BW camber arms, TMS monoball RTABs, ZCP rotors, BW solid caliper guide bushings, PFC 08's, Motorsport Hardware stud kit.
Interior: Cobra Nogaro seats, alcantara headliner, BMW Performance pedals, OE alcantara boots, mason clutch pedal, Xtrons 9" headunit w/ carplay
IG: Zach_e46M
Jump to top . is offline   Reply With Quote
Discussing VAC rod bearings 80 K miles review in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
