Old Sat, Jan-18-2020, 06:55:36 PM   #1
autox124
Reputation: 0 autox124 is on a distinguished road
Default Camber plates on stock suspension
I'm looking for a quiet set of camber plates that work with stock suspension and also don't raise the height of the front of the car? Is this possible or will all camber plates have to raise the car at least slightly in the front?
Jump to top autox124 is offline   Reply With Quote
Old Sat, Jan-18-2020, 07:24:05 PM   #2
Default Re: Camber plates on stock suspension
Usually, a camber plate will reduce stack height fron stock mounts. Unless there are some spacers added in. I believe most makers of plates hace top hats for larger diameter stock springs, just need to specify when ordering.
Old Sat, Jan-18-2020, 07:25:51 PM   #3
Nate047
Nate047's Avatar
Ground Control street plates should suit your needs, and no the ride height won't be affected.
natehasslerphoto.com
@Nate047
Old Mon, Jan-20-2020, 11:25:49 PM   #4
Andrebxp
Reputation: 0 Andrebxp is on a distinguished road
Swap your left and right strut mounts. That should net you about -2.5deg of camber.
Jump to top Andrebxp is offline   Reply With Quote
Old Tue, Jan-21-2020, 12:34:15 AM   #5
JHartman
Reputation: 0 JHartman is on a distinguished road
Swapping left and right won't bind up the struts ?
Jump to top JHartman is offline   Reply With Quote
Old Tue, Jan-21-2020, 01:20:03 AM   #6
Andrebxp
Nope. Been using them as budget camber plates for years.
Old Tue, Jan-21-2020, 01:39:45 AM   #7
///M3_Michael
///M3_Michael's Avatar
Reputation: 0 ///M3_Michael is on a distinguished road
Use a good dry lube on everything during assembly. I've heard others complain about noise but my GC plates are quiet.
2003 ///M3 6MT Slicktop | Phoenix Yellow | Black Nappa | Koni Yellow / Eibach Pro kit | GC Street Plates | 18" Apex ARC-8 | Fabspeed Headers | Fabspeed catted Section 1 | SGT Resonated Section 2 | RE El Diablo | buildjournal B-spec V2.1 tune | Infinity | JL Audio
Jump to top ///M3_Michael is offline   Reply With Quote
Old Tue, Jan-21-2020, 03:03:05 AM   #8
JHartman
Thanks Andre . Useful information .
Old Tue, Jan-21-2020, 07:06:48 PM   #9
Kdubski
Kdubski's Avatar
Ground control street up front, ecs tuning adjustable control arms in back.
-2.0F, -1.6R killer camber specs for spirited driving
Old Tue, Jan-21-2020, 09:00:47 PM   #10
Turner also makes street (quiet) camber plates that work with the stock suspension.
Discussing Camber plates on stock suspension in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
