Closed Thread
Old Fri, Jan-10-2020, 08:38:24 PM   #1
usdmej
Default PSA: know what you're getting into before buying a CSL style intake
this thread is meant to simply inform and is not intended to sway anybody one way or the other on getting a carbon airbox
with the upcoming Turner airbox about to release and the interest that it's churned up, it seems like a lot of people are assuming this will be a simple bolt on intake but that for sure is not the case. it's important to know that there's a significant investment in time and money required beyond simply buying the airbox. At the bare minimum i would suggest you do the following if you're planning to go down this route.
- get familiar with what is actually involved in running a CSL style airbox. there's a fantastic sticky on this
http://www.m3forum.net/m3forum/showthread.php?t=494616
there are a multitude of items (sensors, ducting, wiring, tuning) that will ramp up the costs beyond the initial airbox buy in price. Back in the day these extras weren't so significant when the buy in for just the airbox was $3k-$6k but if your starting price is in the $1k range, you're looking at a significant extra cost to complete your setup (more so if you can't DIY)
- if you're not comfortable doing it yourself. find a shop and verify that they're willing to install it for you and work with you through the potential hiccups. this is not always the case even with reputable shops.
- pick a tuner and make sure you're comfortable working with them. you might think there are a lot of companies that do this based on reading this forum, but there really aren't. some tuners that are mentioned quite often here actually have little to no interest or time to work with you to get your car running right
- realize that even with a tune there are a large number of people that have had problems getting their car running properly. this thread has some good reading on that topic.
http://www.m3forum.net/m3forum/showthread.php?t=536818&
- have a plan when/if something goes wrong. note in the thread previously mentioned that it's still not totally understood why people are having driveability issues with their cars. part of this has to do with variation car to car. For example, a stock E46 M3 seems to run perfectly fine with a failed fuel injector or two, this isn't the case when you switch to a CSL tune. outside of the condition of your car to begin with, if a shop has installed your airbox but you got your tune from another company, there is a chance that one is going to blame the other if you can't get your car running right.
it's easy to be drawn to and romanticize about the things we do to our cars and surely this can cloud our judgement as to whether or not it's all worth it. Hopefully this thread will help clear some of the air around this particular mod.
Jump to top usdmej is offline
Old Fri, Jan-10-2020, 09:32:07 PM   #2
Default Re: PSA: know what you're getting into before buying a CSL style intake
Q: Will I pass smog?
A: No
Jump to top TboneM3 is offline
Old Fri, Jan-10-2020, 09:44:46 PM   #3
usdmej
i didn't want to wade into emissions compliance because smog requirements differ state to state and even county to county
but yes, California smog stations are exceptionally strict with this platform and lets just leave it at that
Old Fri, Jan-10-2020, 09:53:36 PM   #4
cozmo kraemer
cozmo kraemer's Avatar
Reputation: 0 cozmo kraemer is on a distinguished road
A: No
Mine passes the OBD readiness check for AZ emissions with an HP DME Converted to CSL software and a TTFS tune.
but... YMMV
2004 E46M3 - Karbonious CSL intake, Shrick 280/272 cams, CSL DME Conversion, Swaintech coated SSV1 Headers/SS catted/resonated section 1, TTFS tune, Eibach Pro Street S Coilovers (500/600), GC plates, BBS RGR, BMW Motorsport 3.91
2016 - 340i Msport, MPPSK, and track handling package
My Journal
Jump to top cozmo kraemer is offline
Old Fri, Jan-10-2020, 09:58:05 PM   #5
dkl
dkl's Avatar
Reputation: 0 dkl is on a distinguished road
Debbie Downer
J/K - Good PSA
Jump to top dkl is offline
Old Fri, Jan-10-2020, 10:26:23 PM   #6
Steve M3
There are roughly $500 of additional parts needed to get it going, less if you get creative and/or don't have a SMG.
Without the flap, it's not that complicated to set everything up, but I guess it depends on your comfort level and abilities.
Jump to top Steve M3 is offline
Old Fri, Jan-10-2020, 10:43:11 PM   #7
Drewster
Drewster's Avatar
but... YMMV
Smog in CA is also a visual check which this obviously fails.
When they scanned your car, which monitors were ready vs not ready?
Jump to top Drewster is offline
Old Fri, Jan-10-2020, 10:45:36 PM   #8
usdmej
this is not even counting the cost of a tune mind you, the price of which can vary wildly, and is required to make the airbox work.
also, food for thought, if this airbox is going to cost in the $1000 range, you instantly have to add 10% of that cost towards buying an OE CSL air filter
again, i dont want there to be any answers in this thread, just enough information for people to be able to make their own informed decisions.
Old Fri, Jan-10-2020, 10:54:12 PM   #9
Steve M3
Show me on the doll what the CSL airbox did to you...
I used mssflasher and flashed the modified boot sector tune that is readily available, but yes, a dyno tune is recommended to take full advantage of the box as the OE software is setup for euro exhaust and csl cams.
Old Fri, Jan-10-2020, 10:59:25 PM   #10
S54VAGE
Reputation: 0 S54VAGE is on a distinguished road
Yeah getting my car tested this year was such a PITA. First time I went in I think 3 or 4 of my monitors weren't ready due to the original tune that I had..
Luckily the guys at Evolve were super cool about sending me a new one that readied all but 1.. I believe it was the o2s...
@rk.e46
Jump to top S54VAGE is offline
Closed Thread
Discussing PSA: know what you're getting into before buying a CSL style intake in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
