Old Sun, Dec-29-2019, 12:24:32 AM   #11
bimmerfan08
bimmerfan08's Avatar
Default Re: Quick, cheap, and easy VANOS oil pressure gauge
Originally Posted by dutchhome View Post
Note that is not the right size to fit this bolt directly.
Sent from my Pixel 3 using Tapatalk
Put the adapter size needed in my post
"The most difficult part of figuring out a car, the engineering, has been accomplished. Repairs and maintenance are simply dissembling parts and reassembling them." - bimmerfan08
Old Sun, Dec-29-2019, 01:21:18 AM   #12
Considering kpa to bar is just dividing by 100, it might make sense to just use the first gauge and not mess with additional adapters.
Old Sun, Dec-29-2019, 05:00:22 AM   #13
Are there any digital sensors that can fit there? Would be interesting to log the pressure while driving.
https://rover.ebay.com/rover/0/0/0?m...2F301719676258
Old Mon, Dec-30-2019, 07:03:35 PM   #14
DoubleSidedTape
Reputation: 0 DoubleSidedTape is on a distinguished road
To be clear, this is something you would use for testing purposes, you wouldn't want to drive around with this thing on there, right?
Jump to top DoubleSidedTape is offline   Reply With Quote
Old Mon, Dec-30-2019, 07:05:01 PM   #15
heinzboehmer
heinzboehmer's Avatar
Reputation: 0 heinzboehmer is on a distinguished road
I mean you could, but you wouldn't be able to read it lol. Digital sensor for logging sounds interesting though.
Jump to top heinzboehmer is offline   Reply With Quote
Old Mon, Dec-30-2019, 07:05:11 PM   #16
mitch500
mitch500's Avatar
Reputation: 0 mitch500 is on a distinguished road
Right
Sent from my SM-G973W using Tapatalk
97 E36 M3 Coupe Alpine white
s54 swap in progress
Jump to top mitch500 is offline   Reply With Quote
Old Mon, Dec-30-2019, 07:25:19 PM   #17
Drewster
Drewster's Avatar
You can't use that while driving.. he probably means a banjo to 1/8 NPT sensor so you can use a standard stainless sensor like this:
https://www.aemelectronics.com/files...sor%20Data.pdf
Old Tue, Dec-31-2019, 01:01:09 AM   #18
eacmen
Thanks op! I ordered the adapter and plan on wiring a sensor into my data logger.
[RIP] 2001 E46 M3, Tilton Triple Disc Clutch, JRZ RS2 (750/650), ST-40 332mm front BBK, BW TA16 Square 18x9.5, RE-71R 265/35R19, Redish Motorsport Plates, Mason X-Brace, Mason Front Strut Bar, RaceCapture Pro MK3 w/custom Raspberry Pi Dash.
Jump to top eacmen is online now   Reply With Quote
Old Fri, Jan-10-2020, 10:31:36 PM   #19
dutchhome
Reputation: 0 dutchhome is on a distinguished road
Bump so people are aware this option exists before they go spending three times as much.
Jump to top dutchhome is offline   Reply With Quote
Old Fri, Jan-10-2020, 11:44:03 PM   #20
Not even that little. You can get everything for under $30 if you buy in bulk.
Discussing Quick, cheap, and easy VANOS oil pressure gauge in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
