Old Sat, Sep-07-2019, 07:26:48 AM   #1
Impastokitsch
Reputation: 0 Impastokitsch is on a distinguished road
Default M3 starter motor or ELV
Thought is battery and or alternator.
New battery, new alternator changed and battery registered too.
But problem persist.
Sometime without key can't start, u insert key on third attempt it start
Sometime with key cant start, take out key it start
Elv or starter motor
Please advise
Jump to top Impastokitsch is offline   Reply With Quote
Old Sat, Sep-07-2019, 07:41:08 AM   #2
Impastokitsch
Default Re: M3 starter motor or ELV
pls go to the page if there are no audio
Old Mon, Sep-09-2019, 05:36:28 AM   #3
Impastokitsch
Originally Posted by Impastokitsch View Post
https://youtu.be/9QCHv8NAsMQ pls go to the page if there are no audio
Thanks for the pm
Mechanics has tried using voltmeter
They connect it to startermotor wire connected to ecm.
First crank (cant start as usual)
The voltmeter shows constant 12v
Second crank (can start)
The voltmeter shows 12 drop to 10, then engine fire up n voltage back to 12
Based on this, mechanic concluded is starter motor (the solenoid on it) and advised to change starter motor
Discussing M3 starter motor or ELV in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
