Old Fri, Jan-24-2020, 02:46:05 AM   #21
Nuclear Rabbit
Reputation: 0 Nuclear Rabbit is on a distinguished road
Default Re: Engine noise - need experienced opinions
My 05 SMG with 120k made this exact same noise. Thought it was a pulley but also eventually found out it was the TOB. Giveaway for me was that it would not make the noise once in motion (clutch released). Mine wasn't intermittent like yours though
Jump to top Nuclear Rabbit is offline   Reply With Quote
Old Fri, Jan-24-2020, 10:39:55 PM   #22
sapote
Originally Posted by ebg338 View Post
It's an smg so couldn't push the clutch in. The sound started intermittent - at idle the sound would be there, then be gone for a few seconds, then come back. Over time it became more continuous. Shop that fixed it for me didn't indicate they knew what the cause of the bearing failure was - nothing obvious. Car has a little over 100k on it. Over the 50k miles I've owned it it was never tracked or abused, mainly highway miles. Odd that it failed.
TOB in SMG should fail more often than 6mt cars. Reason: waiting at signal lights SMG continued pushing clutch in if driver braked. Riding the clutch is bad for TOB and crank thrust bearing.
"at idle the sound would be there, then be gone for a few seconds, then come back."
I don't remember if the E46 M3 has the TOB constantly touching the PP's fingers. If TOB touched PP all the time then this makes sense. Did you have it in neutral or in gear at idle?
Old Tue, Jan-28-2020, 03:27:03 PM   #23
ebg338
Reputation: 0 ebg338 is on a distinguished road
Always had it in neutral when listening to it but if memory serves the sound was still there when in gear.
Jump to top ebg338 is offline   Reply With Quote
Discussing Engine noise - need experienced opinions in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
