Old Fri, Aug-09-2019, 05:10:40 PM   #31
Default Re: Directory of 3D parts to DIY 3D print/machine
Originally Posted by bryce2113 View Post
I'm going to give these a shot. What material did you end up printing with?
I used makerbot tough PLA, but I'm not sure it's the best option-- it gets a little softer than I'd like when left in very hot places.
Old Fri, Aug-09-2019, 06:23:09 PM   #32
Here's another, though somebody else is going to have to contribute at some point
This is a Qi charger to be installed in the door pocket. It's shorter than the side of the door pocket, so you can only see it if you're above the door pocket looking down on it.
It's sized to fit any generation of Qi enabled iPhone, with an Apple leather case.
The cut out in the back is for the charger (link below), the circle thing is to hold a DC plug maker. The square cutouts are for foam tape (linked) to keep the phone/case from getting scratched up. The missing center is to let you get your fingers under the phone for easy removal.
It's two parts-- the main unit and the back plate. I 3M double sided taped the backing plate to the inside of door pocket and it's plenty secure (and easily reversible).
Here's what both parts look like:
Files: https://www.dropbox.com/sh/ifkzxs3z5...gVT9GL9ma?dl=0
Things you'll need to use this:
USB cable capable of carrying 18 amps
Foam tape
Old Fri, Aug-09-2019, 10:35:22 PM   #33
Drewster
Drewster's Avatar
Last I checked, we're 2 for 2
Old Fri, Aug-09-2019, 11:19:52 PM   #34
Oh crap, I missed that!
Will update post 2.
Old Tue, Aug-13-2019, 06:46:42 PM   #35
sirotto
sirotto's Avatar
Reputation: 0 sirotto is on a distinguished road
Originally Posted by zerotosixty View Post
Any designs better then using tennis balls?
Assuming rear speaker issue?
“Socialism is the philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery” – Winston Churchill
Jump to top sirotto is offline   Reply With Quote
Old Tue, Aug-13-2019, 06:58:06 PM   #36
post 2 brought up to date.
Old Sat, Nov-30-2019, 01:59:42 AM   #37
jeremydde
Reputation: 0 jeremydde is on a distinguished road
Since this is a directory of parts to 3D Print/Machine, and I haven't seen any machined parts yet, I figured it was finally time to post this part. As you can see I machined it out of 6061 aluminum and Lexan, though I'm sure it could probably be 3D printed out of clear filament as well.
When I ordered my Avin headunit, I opted for the reverse camera part as well. Upon closer inspection I found (like many others) that it wasn't even close to being usable. From that point I designed this part to use the led and camera modules from the ill-fitting part and adapt them to the rear of my vert. From what I've heard, the coupe is different, so I'm not sure if it will fit the coupe.
I popped out the existing bulb, bulb carrier, and rear cover from the rear vert and this unit slides right in using the factory license plate cover gasket. The unit was installed fully assembled, with the two left screws (8-32 I believe) loose enough that the machined hook could pass by the housing, then they were tightened up.
Hot glue was used to secure the LED module into the Lexan window.
Below is a link to the files. I have included in the directory a combined STEP, separate STL's and the Fusion 360 F3Z file as well.
Files: https://onedrive.live.com/embed?cid=...GJmTHwsT4XCvj4
Jump to top jeremydde is offline   Reply With Quote
Old Sat, Nov-30-2019, 02:12:14 AM   #38
jeremydde
I designed a 3D printable valve shim tool as it was simple enough that I couldn't justify purchasing one. The thingiverse link is posted below, along with all files, photos, and required neodymium magnet.
Link: https://www.thingiverse.com/thing:3993884
Old Sat, Nov-30-2019, 11:19:13 AM   #39
dutchhome
Reputation: 0 dutchhome is on a distinguished road
Here is a key holder for our keys that I helped my daughter create. We have 2 E46's and an R52 and don't like to attach rings to the keys. This is a nice way to keep them organized.
https://www.thingiverse.com/thing:3657375
Sent from my Pixel 3 using Tapatalk
Jump to top dutchhome is online now   Reply With Quote
Old Thu, Dec-05-2019, 01:03:52 PM   #40
specializedbndt
specializedbndt's Avatar
Reputation: 0 specializedbndt is on a distinguished road
Heres a scaled down S54 Assembly
https://www.thingiverse.com/thing:3115358
Jump to top specializedbndt is offline   Reply With Quote
Discussing Directory of 3D parts to DIY 3D print/machine in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
