Old Sun, Jan-19-2020, 06:05:21 PM   #131
DvSkD4
Reputation: 0 DvSkD4 is on a distinguished road
Default Re: DIY Wrenchers Unite
I have a fluid extractor for helping me certain jobs, but still have tried it with an oil change ... just seems wrong lol
Jump to top DvSkD4 is online now   Reply With Quote
Old Sun, Jan-19-2020, 09:43:57 PM   #132
Originally Posted by Blaikenstein View Post
How legit is this? Iíve been using one and itís awesome. I would think running the engine to get the oil hot would keep the particles suspended?
Most particles will be suspended, and even if there is shift left behind, the oil pickups are behind strainers, and it goes through the filter before lubricating anything.
Old Mon, Jan-20-2020, 12:15:31 AM   #133
Aeko
Aeko's Avatar
Reputation: 0 Aeko is on a distinguished road
Originally Posted by I M Legend View Post
When working on brakes, I like to use old baking trays to catch dirt, brake cleaner, brake fluid, etc. That way I don't have to clean the garage floor.
This but keep an eye out for sales after "cooking" holidays like Thanksgiving and Christmas. You'll sometimes be able to pick up a whole stack of aluminum disposable trays for just two or three bucks. Did that recently, paid about $0.20 a tray and grabbed a handful of deep dish ones for doing coolant system work.
If you wanna make REAL donuts, run Crisco in your diff.
Jump to top Aeko is online now   Reply With Quote
Old Mon, Jan-20-2020, 02:55:14 AM   #134
11b4
11b4's Avatar
Originally Posted by Isi 78 View Post
Quick but all the "dirt" remains at the bottom of the oilpan
Wrong. But every coupe oil changes I still remove the drain plug to see if there's anything left. Which mostly isn't.
Sent from my Pixel 3 XL using Tapatalk
Old Wed, Jan-22-2020, 01:25:33 AM   #135
YVRCSM Vert
YVRCSM Vert's Avatar
Reputation: 0 YVRCSM Vert is on a distinguished road
[QUOTE=11b4;1068023347]Wrong. But every coupe oil changes I still remove the drain plug to see if there's anything left. Which mostly isn't.
I've been a marine mechanic for over 30 years. On most boats the only way to get the oil out is through the dipstick. I've never seen any failures that could be traced back to the tiny bit of oil that doesn't come out with this method.
Jump to top YVRCSM Vert is offline   Reply With Quote
Old Wed, Jan-22-2020, 01:48:28 AM   #136
DvSkD4
[quote=YVRCSM Vert;1068023820]
Thatís good to hear from someone with that much first hand experience, maybe I ought to try it this spring.
Old Mon, Feb-03-2020, 05:40:27 AM   #137
mrgizmo04
mrgizmo04's Avatar
Posting for information purposes based on recent discussion about oil changes.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
'04 S2000
All DIY: VANOS, WPC rod bearings, full SS (SS stepped V1 headers, catted S1, resonated S2, SS sport), AFD E85 Proflex kit, Ohlins R&T/Hyperco 375f Swift 672r/GC street tops and camber plates, ST40 355 pfc08, 330 ZHP steering rack, diffsonline 4.1 diff with rem polish, E60 short shifter lever, AKG black diff bushings/subframe bushings, Rogue rtab, Sachs clutch/flywheel, rear main, Beyer driveshaft, valve adjustment, cooling refresh.
Discussing DIY Wrenchers Unite in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
