Old Mon, Dec-30-2019, 09:06:52 PM   #171
Fresh1179
Fresh1179's Avatar
Reputation: 0 Fresh1179 is on a distinguished road
Default Re: Comprehensive CSL Intake Thread
Thank god the forum is back up so I can ask a simple question that I can't quite get clarification on (searched forum's, contacted Kassel etc.) Is there any reason that the TTFS rail (and Karbonius airbox) with the MAP sensor would not work with their conversion kit harness? I am mainly interested in the harness for a "simple and clean" install. I know I could just do it myself, but hey, looks like someone might have already done it for me. Any input is appreciated.
Side note: They also offer MSS54 to MSS54HP conversion, but I have no idea whether that canned conversion would throw a bunch of codes on a 6MT with no other modifications. Anyone been this route? Otherwise I was thinking of contacting Paul Claude.
Thank You.
Enjoy Every Sandwich-Warren Zevon
Jump to top Fresh1179 is online now   Reply With Quote
Old Mon, Dec-30-2019, 10:13:30 PM   #172
repoman89
repoman89's Avatar
Reputation: 0 repoman89 is on a distinguished road
^The Kassel MAP kit is basically the NZ M3 updated sensor ... look up his thread. You can plug that (Bosch I believe) sensor into the CSL or TTFS rail with a different o-ring and then could use the Kassel harness, but at that point you might as well make your own. You’re paying for the little aluminum piece that plugs into the air rail. The sensor and harness parts are dirt cheap.
I did the Kassel MSS54HP H-bridge conversion so that I could use the flap and the flash that came on it worked fine for my 05 6MT. It will start and run fine but you should contact PC anyway to get a version that’s dialed in for stock US/Euro cams.
Jump to top repoman89 is offline   Reply With Quote
Old Sat, Jan-04-2020, 04:55:32 PM   #173
Fresh1179
Fresh1179's Avatar
Default Comprehensive CSL Intake Thread
So...Iím a tad confused here. I know I have to get my MSS54 converted to a MSS54HP. I pulled the DME from my car ten seconds ago and it appears I have a MSS54HP. So the question becomes, do I still need to send it off to be reflashed with the CSL software or can I just flash the CSL software onto the current DME myself? I have a stock US M3. Iím trying to make this easiest on myself. I am planning to send it off to PC but I donít know if that is necessary? I apologize for the simple question but Iíll admit software and electronics is not my forte in the car servicing game.
Old Sat, Jan-04-2020, 05:12:39 PM   #174
ChipperM3
Reputation: 0 ChipperM3 is on a distinguished road
Hereís a start if you want to do it that way:
Running CSL software on stock MSS54HP
[URL="http://www.m3forum.net/m3forum/showthread.php?t=495986k"]
Jump to top ChipperM3 is offline   Reply With Quote
Old Wed, Jan-08-2020, 06:32:21 PM   #175
Fresh1179
Fresh1179's Avatar
Does anyone know what Bar the TTFS rail comes with. There are no markings on it and I can't reach anyone there. Thank you.
Old Mon, Feb-24-2020, 05:40:09 PM   #176
Zzyzx85
Zzyzx85's Avatar
Reputation: 0 Zzyzx85 is on a distinguished road
I finally got my Karbonius box installed this past weekend.
However, I got this error message. Anyone have an idea what's causing it? I've already double checked the wiring (first tried Turner's IAT relocation harness.
Then I tapped into #1 and #3 wire at MAF connector directly) and made sure my tune (Kassel) is scaled for OE type IAT sensor (Beru). Bad sensor maybe?
2003 M3 IR/black - "bought with 195k miles pre-installed"
Beisan - WPC rod bearings - Karbonius airbox (no flap) w/ CSL Kassel converted and tuned MSS54HP DME - JRZ RS One 450F/550R - GC Race camber/caster plates - GC weight jacks - GC RSM - Z3 steering rack - Volk Racing G2 18x9.5 square - Turner camber arms - Redish RACP plates - SyncroDesignWorks RTAB - Bride Euroster II (black gradation) - OE LED taillights - AS 30% SSK
ig
Jump to top Zzyzx85 is online now   Reply With Quote
Old Mon, Feb-24-2020, 06:56:00 PM   #177
sddynamix
sddynamix's Avatar
Reputation: 0 sddynamix is on a distinguished road
However, I got this error message. Anyone have an idea what's causing it? I've already double checked the wiring (first used Turner's IAT relocation harness.
Then I tapped into #1 and #3 wire at MAF connector) and made sure my tune (Kassel) is scaled for OE type IAT sensor (Beru). Bad sensor maybe?
Interested in this as well, I get these periodically.
Jump to top sddynamix is offline   Reply With Quote
Old Mon, Feb-24-2020, 11:02:16 PM   #178
Zzyzx85
Zzyzx85's Avatar
If you can check with INPA's live readout, are you usually getting the correct IAT temp?
ig
Discussing Comprehensive CSL Intake Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
