Old Sun, Jun-18-2006, 05:03:40 AM   #1
DreddM3
Reputation: 0 DreddM3 is on a distinguished road
Default Possible to clean out gas tank, every so often?
How hard is it to reach and deattach the gas tank on an E46? Considering all the **** that gets built up, removing it every 3 months and flushing it clean would be nice ... possible for DIY?
Jump to top DreddM3 is offline   Reply With Quote
Old Sun, Jun-18-2006, 02:46:24 PM   #2
Irrenarzt
HNIC
Irrenarzt's Avatar
Reputation: 0 Irrenarzt is on a distinguished road
Yes but it is a lengthy job. You need to remove a lot of stuff to get it out. Do the Turner subframe reinforcement plates while you are at it.
Jump to top Irrenarzt is offline   Reply With Quote
Old Sun, Jun-18-2006, 04:14:29 PM   #3
stickercutting
Reputation: 11 stickercutting has disabled reputation
I think this is just a tad bit extreme.
Don't waste your time. BMW wouldn't design a car that would need this.
Jump to top stickercutting is offline   Reply With Quote
Old Sun, Jun-18-2006, 05:22:35 PM   #4
Chris(NJ)
Back home in Jersey
Chris(NJ)'s Avatar
Reputation: 0 Chris(NJ) is on a distinguished road
I havent been under the car yet.....but isnt there a drain plug? This way you dont have to remove the whole thing. I would think if you removed the plug, any fuel that dumps out should drag out some debris, although not all of it, enough to keep it relatively clean enough.
2002 Topaz/Black M3-Slicktop-SMG: OEM CSL Bootlid, Mini-CSL Battery, TMS Pulleys, Stoptech SS Lines, Borla muffler & Midpipe, Hotchkis Sways, Eibach Springs, RE RSMs, PowerFlex Rtabs, PowerFlex Subframe Bushings, TMS Subframe Reinforcement, Blk Grills, Blk Side Gills, VCSL Center Console, Euro Front Bumper, Hamann Fog Ducts, ACS Lower Lip Spoiler, FUCY Rear Diffuser, LED Tail upgrade w/ outer ring mod, D/A street software, RPI Scoops, e92 m3 18" rims w/ PS2s
Jump to top Chris(NJ) is offline   Reply With Quote
Old Sun, Jun-18-2006, 05:34:29 PM   #5
ArtM3
Reputation: 0 ArtM3 is on a distinguished road
no drain, as far as I can tell from the parts pic...
but I doubt there is much stuff in there...it gets mixed up (solution & suspension) as you drive and is pumped out, and caught by the filter...
Jump to top ArtM3 is offline   Reply With Quote
Old Sun, Jun-18-2006, 10:29:01 PM   #6
DreddM3
I've read on multiple occaisions of peoples fuel pumps failing because of running the tank to low and clogging it with the debris... replacing a fuel pump isnt extreme... but I've also read that it can mess with your injectors, and other engine components... and those are expensive.
Old Sun, Jun-18-2006, 11:25:38 PM   #7
ArtM3
the pump is most likely a positive displacement type...so it's got clearence to pass dirt, which will be caught by the filter...nothing should get to the filter, as it gets dirty (higher DP drop) the regulator mounted to it keeps a constant pressure...
the storage tanks at the station act as settling tanks, and let what little crud in the gas, fall out...the pump pick up is off the bottom of the tank so it's not sucked in...that's why I won't buy gas if I see a tanker filling the tanks...stirs up the sediment
I had to clean the level sending unit in my e36 M3, pulled the rear seat and removed the sender...no crud in the tank at 150k miles or so...
new tanks are plastic, on older metal tanks, with crapier gas, rust & scale over a long time may be a problem...not really anymore...
Old Mon, Jun-19-2006, 03:51:44 AM   #8
24601
what goes around comes around...pay it forward
24601's Avatar
Reputation: 0 24601 is on a distinguished road
awesome info once again. thanks.
'06 M3 | '07 A3 2.0T S-Line | '17 GLC43 (hers)
Jump to top 24601 is offline   Reply With Quote
Old Mon, Jun-19-2006, 04:24:55 AM   #9
tripower
tripower's Avatar
Reputation: 0 tripower is on a distinguished road
Are you looking for something to keep you busy? Ever hear of a fuel filter?
This is a very difficult and messy procedure and I assure you if you accomplished this once you would not attempt it again, much less try it every three months.
Jump to top tripower is offline   Reply With Quote
Gas Tank Capacity M3samurai E36 FAQ 10 Sun, Jul-01-2012 09:46:28 PM
Gas Tank Venting Kneedrager M3 Track: Racing and DE 1 Sun, Jan-29-2006 06:15:13 PM
Whistling gas tank? bigneil E36 M3 (1992-1999) 13 Fri, Jan-20-2006 02:30:38 AM
Bad tank of gas? ///MX E36 M3 (1992-1999) 0 Sat, May-07-2005 05:25:19 AM
How many KMs do you get per tank of gas? silicuda E46 M3 (2001-2006) 6 Wed, Mar-05-2003 03:17:36 AM
Discussing Possible to clean out gas tank, every so often? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
