Old Tue, Jan-09-2018, 04:17:13 AM   #811
Default Re: The Official E46 M3 Oil Analysis Results Thread
Originally Posted by TheDoogan View Post
UPDATE:
Okay guys,
Alex @ Perf Euro says that alone the copper level isn't too alarming, but that the lead and iron levels are "very notably high". He says that with those two levels being high, the copper levels could shoot up quickly.
So: I'm adding rod bearings to the work order. Whew, hopefully The //Mander doesn't find out what this costs. =D
He did say: the fuel % isn't much cause for concern, as short drives or idling can cause that range; but to keep doing analysis each change to keep tabs on it.
Boom. You'll feel better having done everything at once.
All DIY: 330 ZHP steering rack, diffsonline 4.1 diff with rem polish, E60 short shifter lever, AKG black diff bushings/subframe bushings, Rogue rtab, Rogue RSM with reinforcement, WPC rod bearings, Beyer driveshaft, Magnaflow catback, new SAC/flywheel, rear main, VANOS bullet proofing with anti-rattle, valve adjustment, cooling refresh.
Old Thu, Jan-11-2018, 04:50:05 PM   #812
TheDoogan
Forward Loaded
TheDoogan's Avatar
Reputation: 0 TheDoogan is on a distinguished road
Hello guys, for the record (to correlate my oil analysis above with the condition of the rod bearings), this in from Alex @ Perf Euro:
Hey Patrick
Thank you for all the information. Will try to review this all tonight. Really quick update:
Rod Bearings
REALLLLLLY glad we started this. A handful of the bearings are down to the copper on the edges. Quite a few more have pitting and layers worn off.
Your oil analysis was absolutely indicative of the condition of your bearings. I'm more surprised that the analysis company said that it was ok to continue with these bearings.
Clutch
Clutch, pressure plate, throwout bearing are all in.
Subframe
I quickly inspected it to get an idea on what we're working with. There is a VERY small crack forming in the front passenger mounting point of the rear subframe carrier panel. Nothing out of the ordinary. We will be able to fix this up without extra cost. I am hoping to have the whole rear end down by tonight and continue prepping the surface to weld in the new plates.
Parts
Got confirmation from suppliers that your subframe bushings and cams should be here by early next week. Once the cams are in, we can move forward with the VANOS repair.
Everything is progressing very well. Bottom of car is immensely clean, no corrosion, hardware is in good condition.
We will keep chipping away at the project and update you along the way. I'll do my best to collate all of the photos for your records and entertainment.
Thanks!
Alex
Also a good reason to only use BlackStone I'm guessing. This local company probably has no database.
2006 E46 M3, 6MT, Convertible, Black/Black - 68k miles
Active Autowerke Catless Headers, Section 1 High-flow cats & Section 3, Evolve CSL Intake w/Alpha-N tune
Last edited by TheDoogan; Thu, Jan-11-2018 at 05:12:41 PM. Reason: Perf Euro, not Perf Auto
Jump to top TheDoogan is offline   Reply With Quote
Old Thu, Jan-11-2018, 04:56:11 PM   #813
Blackstone also seems to like to recommend not doing bearings.
I think it's important to remember that these companies deal with all engines and don't necessarily knock what s54 specific issues/symptoms are.
Current Cars: 2005 IR/IR M3, 2001 LMB/blk M5, 03 530i, 04 M3 wagon
Old Thu, Jan-11-2018, 05:37:09 PM   #814
TheDoogan
Forward Loaded
TheDoogan's Avatar
Good point! Now Ian, I'm curious: is the metallic makeup of these bearings designed this way so that oil analysis reveals their health - with the copper, and lead? Or is that a fortunate coincidence, that we can roughly determine their wear without inspection?
Old Thu, Jan-11-2018, 05:40:13 PM   #815
They are not constructed with oil analysis in mind.
Sadly, it's also no longer possible on later production e9X M3s, either-- and they have much worse bearing issues than we do!
Old Thu, Jan-11-2018, 06:02:00 PM   #816
M3_Pilot
Yeah, they went from lead/copper to aluminum. Which is a harder metal but I think the s65 has more of a clearance issue than anything else.
2004 Jet Black/Cinnamon 6MT
Old Thu, Jan-11-2018, 09:21:35 PM   #817
ThunderMoose
It's not perfect but it's directionally correct. I DIY so changing bearings on a schedule is not that costly. Bearings themselves are relatively cheap.
#67 2017 NASA TX TT3 Champion
Jump to top ThunderMoose is online now   Reply With Quote
Old Thu, Jan-11-2018, 10:01:55 PM   #818
whips333
whips333's Avatar
Reputation: 0 whips333 is on a distinguished road
My blackstone results
Jump to top whips333 is online now   Reply With Quote
Discussing The Official E46 M3 Oil Analysis Results Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
