Old Fri, Oct-12-2018, 02:25:02 AM   #1
josee_alvarenga
Reputation: 0 josee_alvarenga is on a distinguished road
Default Oil leak cpv
hey guys, working on finding an oil leak. For those that had to replace their CPV, was the leaking very little?? or was it leaking a lot? mine is leaking quite a bit, passenger side of car, all over headers, front control arms, and part of the brakes so iím not sure if my symptoms are that of a faulty pressure valve
Jump to top josee_alvarenga is offline   Reply With Quote
Old Fri, Oct-12-2018, 03:33:10 AM   #2
TheSt|G
Resident Curmudgeon
TheSt|G's Avatar
Isle of Man
Default Re: Oil leak cpv
It is going to leak eventually if you don’t replace it. So do the upgrade, clean the area, see if the mess returns.
Old Fri, Oct-12-2018, 03:41:35 AM   #3
josee_alvarenga
meant to write that i didnít know where my car was leaking from but i suspected the CPV, but youíre right i think i should replace the O ring anyways now that iím down there
Old Fri, Oct-12-2018, 05:16:20 AM   #4
mrgizmo04
mrgizmo04's Avatar
From what you are describing, I'm not sure it's the cpv in your case...
All over headers - which cylinders, bank 1 or 2 collectors? CPV is basically just under cyl#6, very close to the bell housing.
All over front control arms and brakes...those are too far forward of the CPV location to be the CPV...and the brakes are pretty isolated in wheel well, especially if you have all the undertrays intact.
My guess is the chain tensioner, that sits under cyl#1 and more inline with the area you are describing...
Get some paper towels and start dabbing all around (once car is cool so you don't burn yourself).
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Fri, Oct-12-2018, 07:12:10 AM   #5
Or Vanos accumulator.
_
Old Fri, Oct-12-2018, 07:26:56 AM   #6
mrgizmo04
mrgizmo04's Avatar
Very good point, T!
OP - check/follow the high pressure line from vanos unit to where it "disappears" around the bank 1 headers. Those lines are known to bust/leak.
'05 M3 6MT coupe
Old Fri, Oct-12-2018, 03:29:15 PM   #7
toy4to
Lemonade Tycoon
Reputation: 0 toy4to is on a distinguished road
I just had this same issue with my chain tensioner. Remove the plastic piece on the passenger side engine bay and look at the area above your AC compressor. Look for any oil around that area. If there is, either tighten the chain tensioner, or replace the gasket. Note that there have been a lot of stories of people crossthreading this chain tensioner when they put it back in.
This link may help you. The square drive socket cap made the job soooo easy. A $4 tool.
http://www.m3forum.net/m3forum/showthread.php?t=433414
Jump to top toy4to is online now   Reply With Quote
Old Fri, Oct-12-2018, 03:38:49 PM   #8
I love those socket caps! Made swapping the tensioner, and other stuff, so much easier. And it's not like I don't have lots of different tools; the caps just make life easier in some situations.
_
Old Tue, Oct-16-2018, 02:43:55 AM   #9
josee_alvarenga
thanks a lot guys! i really appreciate the links you all sent me. itís not the CPV, i just took out the tensioner, checked the washer and it seemed perfectly fine with no defections.... couldnít fit a torque but tightened it quite hard with the open end wrench i was using. not sure if i should have ordered a new washer either way but tomorrow iím gonna check the vanos pressure line to see if thatís the culprit.
Old Tue, Oct-16-2018, 02:49:20 AM   #10
josee_alvarenga
used UV dye and dabbed my fingers on TCT, UV light showed green. ran my fingers far down oil pressure line and fingers turned green as well under UV light. although oil somehow could have managed to find its way on that pressure line so that test isnít tooo accurate... is there anything else in that region i should check??
Discussing Oil leak cpv in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
