Old Thu, Oct-11-2018, 11:05:30 PM   #1
naav
Reputation: 0 naav is on a distinguished road
Default For speakers, possible to change rear passenger panel?
So I got a set of used BAV sound speakers...
My rear passenger side has 1 tweeter on each side (e.g pic attached, black seats). The bav sound has a tweeter and midbass (pic attached, grey seats).
My question is, could I go to the junk yard and get a set of rear panels with the 2 speaker configuration? Would mine have the mount points for the midbass speaker?
Second, what would I have to do with the wiring? would need a crossover i imagine.
My m3 has the buisness CD unit, eventually will swap it out for sony carplay unit.
Jump to top naav is offline   Reply With Quote
Old Fri, Oct-12-2018, 11:52:28 PM   #2
JamesSJ1
Reputation: 0 JamesSJ1 is on a distinguished road
Default Re: For speakers, possible to change rear passenger panel?
I was writing a technical post about doing this, and realized you have a different problem entirely. The second picture, with tweeter and mid-bass in the panel, is from a convertible. It has no rear deck speakers, so the rear bass/midbass has to come from the side panels instead. That panel card probably isn't compatible with a coupe either.
If you did figure this out, the answer is no...you couldn't just split off the tweeter line with a cross-over. It's probably already crossed over in the amp, which means it wouldn't drive anything less than around 1500-3000hz. You would need to bring lines down from the rear deck to the mid-bass in the panel cards, and that might tax that channel from the amp. Why not just upgrade the rear deck speakers if you're looking for better sound there? I don't think adding side mid-bass speakers would do much when you already have rear deck speakers.
Jump to top JamesSJ1 is offline   Reply With Quote
Old Sat, Oct-13-2018, 01:52:48 AM   #3
naav
Thanks for the reply James! That makes sense.
So I'll just work on upgrading the 6x9 rear speakers.
Cheers
Discussing For speakers, possible to change rear passenger panel? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
