Old Thu, Oct-11-2018, 05:27:09 PM   #1
Patrick4588
Patrick4588's Avatar
Reputation: 0 Patrick4588 is on a distinguished road
Default e46 M3 diff power limit?
Does the dif and lsd hold high hp well? for say 1000+, am i needing to move to a Quaife lsd or will the stock lsd handle that alright? I will need to go to 3.15 gears and have them rem polished and cryo treated
1987 325i. Tube chassis drag car, LSX, F1X-12. M1 methanol car
2002 Corvette Z06 408ci F1R
2003 M3 Procharged 427 LSX
2006 Trailblazer ss 408ci + nitrous
2017 Corvette z06 FBO e85
Jump to top Patrick4588 is offline   Reply With Quote
Old Fri, Oct-12-2018, 01:02:41 AM   #2
bosundave
Reputation: 0 bosundave is on a distinguished road
Default Re: e46 M3 diff power limit?
Talk to John at Lab22.
OS Gikken will custom build a set up for you. I would go that way. But your half shafts will eventually shatter. I broke two with only 300rwhp.
Drive Shaft shop will rebuild your half shafts to handle 1000RWHP.
Might want to read this:
1000 HP E46 M3
http://www.superstreetonline.com/fea...hp-e46-bmw-m3/
I wasn't speeding...I was QUALIFYING!
Agency Power muffler , Ebay midpipe, Magnaflow resonators BREMBO GT BBK, Endless Racing brake pads , TC Kline SA Coilover (front) Swift 448lb springs, BC Racing coilover rears (for now), TMS front(30mm) and rear(25m) adjustable anti sway bars, AKG FCABS, TMS limiters on AKG RTABs, and powerflex subframe bushings, HPF AND TMS weld in Subframe kit, 10 hours of additional subframe Stitch welding above and beyond what's usually called for, CF trim interior and exterior clear coated by my guy with heavy duty UV protection, Vorsteiner CF rear diffuser, Strassentech type CF lip, Aurora Angel Eyes, DRL,HID Fogs 6k, Headlights HID 6k, D-Force racing wheels sandblasted and powder-coated semi-gloss black, Square set up 265/35-18, built-in Passport Escort 9500CI .. custom mount of controls in ash tray, , rareQuatro CF shock tower brace, Pioneer Avic Z3, BSW stg 1speakers, BSW sub
Jump to top bosundave is offline   Reply With Quote
Old Fri, Oct-12-2018, 01:08:31 AM   #3
ggrslc
Reputation: 0 ggrslc is on a distinguished road
Nothing on your BMW is gonna stand up to repeated wot applications from a 1000hp engine. Not the engine, not the clutch, not the driveshaft, not the differential, not the subframe. Why do you think top fuelers rebuild their motors after about three minutes of operation. I know....been there.
Jump to top ggrslc is offline   Reply With Quote
Discussing e46 M3 diff power limit? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
