Old Wed, Oct-10-2018, 03:31:19 PM   #1
LemonOne
LemonOne's Avatar
Reputation: 0 LemonOne is on a distinguished road
Default BMW E46 M3 - S54 Engine High RPM Noise
Recently, I am starting to hear metal tingling sound (quietly) whenever it goes over 5K RPM and holding constantly.
I am wondering if this noise is normal or related to valve adjustment/maintenance issue.
Any thoughts?
2006 Imola Red / Cinnamon SMG II
Jump to top LemonOne is offline   Reply With Quote
Old Wed, Oct-10-2018, 03:32:31 PM   #2
rbmwiv
rbmwiv's Avatar
Reputation: 0 rbmwiv is on a distinguished road
Default Re: BMW E46 M3 - S54 Engine High RPM Noise
Could be vanos
Jump to top rbmwiv is offline   Reply With Quote
Old Wed, Oct-10-2018, 04:02:33 PM   #3
Drewster
Drewster's Avatar
Like rocks in a coffee can? Sounds like you need to maintain the car a little better (misfiring)
Old Wed, Oct-10-2018, 04:06:46 PM   #4
rbmwiv
rbmwiv's Avatar
Any lights on and if so whatís the codes? Also service history when was your last valve adjustment. It could be many things from the front of the engine to the back. If something happened to the clutch it can cause noises. What can happen with a clutch to make a noise like that is one of the fingers on the pressure plate breaks loose and makes racket.
Old Wed, Oct-10-2018, 04:16:42 PM   #5
LemonOne
LemonOne's Avatar
The sound is very minor, engine still pulls very strong, no rattle or anything and no lights.
No engine hiccups or anything. Just trying to get some idea if anything needs to be done before the sound gets louder/worse.
Old Wed, Oct-10-2018, 04:19:12 PM   #6
LemonOne
LemonOne's Avatar
Nothing like that, just very quiet metal tingling sound from the engine when holding onto high rpm.
Old Wed, Oct-10-2018, 04:20:29 PM   #7
rbmwiv
rbmwiv's Avatar
When was your last valve adjustment?
Old Wed, Oct-10-2018, 04:29:49 PM   #8
LemonOne
LemonOne's Avatar
It was done around 65k miles, now it has 90k miles.
I did not hear any ticking sound when cold or hot.
Old Wed, Oct-10-2018, 05:30:49 PM   #9
///M3 MD
Reputation: 0 ///M3 MD is on a distinguished road
Iíd get it looked at by a professional if I were you. Could be a lot of things, most of which wonít be diagnosed by us keyboard warriors. Consider just getting a valve adjustment (youíre pretty much due for it anyway based on mileage alone) and do a compression test while your in there to ensure you donít have a head gasket leak (which can cause a lot of issues and misfires/detonation).
2002 Carbon Black/Black 6MT ///M3
Mods: (Mike Miller Maintenance schedule) - Euro Headers - Resonated Section 1 - Dinan Section 3
TTFS Custom Tune
Autosolutions 30% SSK - RE Poly Trans mounts - AKG Poly diff bushings, RTABs and FCABs
Dinan 'Stage 1' Suspension
Jump to top ///M3 MD is offline   Reply With Quote
Old Wed, Oct-10-2018, 11:32:27 PM   #10
andrewrivera141
Reputation: 0 andrewrivera141 is on a distinguished road
Video?
Sent from my Pixel using Tapatalk
Jump to top andrewrivera141 is offline   Reply With Quote
Discussing BMW E46 M3 - S54 Engine High RPM Noise in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
