Old Wed, Oct-10-2018, 03:47:43 PM   #11
Default Re: TPMS woes
Originally Posted by lmtfi View Post
Did you check/equalize the pressure in the new tire with the other rear? What is that pressure?
Did you do the full re-learn procedure in key position 2?
The fact that this follows a new tire installation suggests that you aren't doing the correct re-learn procedure.
^yep
Old Wed, Oct-10-2018, 04:36:06 PM   #12
burningchrome
Reputation: 0 burningchrome is on a distinguished road
Tire was replaced Saturday night, so I was very carefully monitoring pressures after. I think I did the relearn with the car running; should I have done it not running but position 2?
Jump to top burningchrome is offline   Reply With Quote
Old Wed, Oct-10-2018, 04:36:15 PM   #13
rbmwiv
rbmwiv's Avatar
Reputation: 0 rbmwiv is on a distinguished road
1. Check Tire Pressure to make sure no variance from side to side.
2. Sit in car, with out touching the pedals.
3. Key in ignition, Turn key on to engine off position (second position).
4. Press and hold TPM until TPM lights go out completely on the dash.
5. Press and hold TPM again until yellow TPM light indicator comes lit on dash.
6. Start car and drive. Light will go off itself once it has calibrated tire pressure. (might go out at idle).
Jump to top rbmwiv is online now   Reply With Quote
Old Wed, Oct-10-2018, 11:58:46 PM   #14
LINDW4LL
LINDW4LL's Avatar
Reputation: 0 LINDW4LL is on a distinguished road
I'm having the same problem. I'll attempt the relearn procedure once more tomorrow (ensuring engine off) just to make sure I'm not crazy.
Though I'm skeptical, I've seen it suggested that bad RTABs can cause enough rotational difference to throw the light; they should be worn with my mileage but I've not observed any uneven tire wear or other typical symptoms.
2003 ///M3
| Stahlgrau | FABSPEED Headers | Section 2 EVC | buildjournal |Turner MS Sway Bars | Bilstein | Pilot Sport 4S | Porterfield R4-S | OE LED Tails | M-Track DSC |
Jump to top LINDW4LL is offline   Reply With Quote
Old Thu, Oct-11-2018, 12:01:21 AM   #15
rbmwiv
rbmwiv's Avatar
This is copied straight from BMWs tis.
Old Thu, Oct-11-2018, 10:26:27 PM   #16
bosundave
Reputation: 0 bosundave is on a distinguished road
My light is acting up again (since I read this thread...LOL).
I have exact pressures side to side. I have two matching 256/35-18's up front and two matching 265/35-18 in the rear.
I just rotated the pairs. I bet the calibration procedure will fix my issue. I never remember having to do this before.
Other issues may possibly be ancient possibly dirty sensors.
But many thanks for the calibration instructions.
I wasn't speeding...I was QUALIFYING!
Agency Power muffler , Ebay midpipe, Magnaflow resonators BREMBO GT BBK, Endless Racing brake pads , TC Kline SA Coilover (front) Swift 448lb springs, BC Racing coilover rears (for now), TMS front(30mm) and rear(25m) adjustable anti sway bars, AKG FCABS, TMS limiters on AKG RTABs, and powerflex subframe bushings, HPF AND TMS weld in Subframe kit, 10 hours of additional subframe Stitch welding above and beyond what's usually called for, CF trim interior and exterior clear coated by my guy with heavy duty UV protection, Vorsteiner CF rear diffuser, Strassentech type CF lip, Aurora Angel Eyes, DRL,HID Fogs 6k, Headlights HID 6k, D-Force racing wheels sandblasted and powder-coated semi-gloss black, Square set up 265/35-18, built-in Passport Escort 9500CI .. custom mount of controls in ash tray, , rareQuatro CF shock tower brace, Pioneer Avic Z3, BSW stg 1speakers, BSW sub
Jump to top bosundave is offline   Reply With Quote
Old Thu, Oct-11-2018, 10:28:00 PM   #17
bosundave
This is certainly interesting and seems very possible.
Old Fri, Oct-12-2018, 04:25:30 AM   #18
mrgizmo04
mrgizmo04's Avatar
I had mine acting up for a while even though pressures side to side where equal. I had to drop pressures a few psi and then it stopped acting up.
So equal doesn't mean proper.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Fri, Oct-12-2018, 09:36:48 AM   #19
bosundave
My red warning light came on again tonight. I recently rotated my tires and that's probably why.
I pulled over on the way to work tonight, and followed the instructions for the relearn process. The yellow light went out before I started rolling. I bet this is going to solve the problem.
I vaguely remember doing this a long time ago. But I had completely forgotten about it. Thanks for the reminder.
Old Sat, Oct-13-2018, 02:22:12 PM   #20
LINDW4LL
LINDW4LL's Avatar
Update: I had in fact been attempting the reset procedure with the engine running previously. Light went off at idle after following the correct procedure, and I put 1000 miles on since Thursday; no light. To think I stared at that daily for the past several months... Ouch!
2003 ///M3
Discussing TPMS woes in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
