Old Tue, Oct-09-2018, 10:36:23 PM   #1
burningchrome
Reputation: 0 burningchrome is on a distinguished road
Default TPMS woes
My TPMS light keeps coming on red every couple days. I'll check the tires, and the pressures are fine. I reset it, a couple days later, it's back. What sensor is failing?
Jump to top burningchrome is offline   Reply With Quote
Old Tue, Oct-09-2018, 10:41:08 PM   #2
rbmwiv
rbmwiv's Avatar
Reputation: 0 rbmwiv is on a distinguished road
Default Re: TPMS woes
Possible your abs sensors are dirty. Pull them from each spindle and clean the build up off they are magnetic. The way the car determines if the pressure is low it uses the abs sensors because a tire with a higher pressure will have less overall revolutions than a tire thatís low on air. Thereís no sensors in the wheels on a e46.
Jump to top rbmwiv is offline   Reply With Quote
Old Tue, Oct-09-2018, 10:53:14 PM   #3
kokgo20
kokgo20's Avatar
Are you sure that you are resetting it correctly also?
Build thread
Old Tue, Oct-09-2018, 11:45:11 PM   #4
lmtfi
lmtfi's Avatar
New tires?
Which re-learn procedure are you using?
Old Wed, Oct-10-2018, 01:12:44 AM   #5
bosundave
Reputation: 0 bosundave is on a distinguished road
Mine acted up when I put new tires on the rear. I cleared it three or four times and it never came back. That was a month ago.
I hate our TPMS. Best addition I ever bought for my M3 is this solar power TPMS system for less than 50 bucks. I got the external sensors in the valve caps because I have a square set up and rotate my tires. All I have to do is swap valve stem caps. They are very water proof and holding up well.
Temperature and pressure read-outs seem amazingly accurate. Within a single PSI. I watch the temps rise as I drive and the resulting PSI increase.
I did not see (night time.very dark) one tire completely flat because of a nail I picked up. The alarm on the unit was sounding to alert me one of my tires was below 35psi (I set that value). It was 0 psi, actually. I patched it with a plug(worked 100%) and actually ended replacing both my rears a week later.
I see now that it is rated "Amazon's Choice" in TPMS $47.99
I recommend this tire pump. Just set the pressure and it has auto shut off. Love it. $36.77
I wasn't speeding...I was QUALIFYING!
Agency Power muffler , Ebay midpipe, Magnaflow resonators BREMBO GT BBK, Endless Racing brake pads , TC Kline SA Coilover (front) Swift 448lb springs, BC Racing coilover rears (for now), TMS front(30mm) and rear(25m) adjustable anti sway bars, AKG FCABS, TMS limiters on AKG RTABs, and powerflex subframe bushings, HPF AND TMS weld in Subframe kit, 10 hours of additional subframe Stitch welding above and beyond what's usually called for, CF trim interior and exterior clear coated by my guy with heavy duty UV protection, Vorsteiner CF rear diffuser, Strassentech type CF lip, Aurora Angel Eyes, DRL,HID Fogs 6k, Headlights HID 6k, D-Force racing wheels sandblasted and powder-coated semi-gloss black, Square set up 265/35-18, built-in Passport Escort 9500CI .. custom mount of controls in ash tray, , rareQuatro CF shock tower brace, Pioneer Avic Z3, BSW stg 1speakers, BSW sub
Jump to top bosundave is offline   Reply With Quote
Old Wed, Oct-10-2018, 12:30:17 PM   #6
burningchrome
Resetting by holding down the button until red goes off and yellow comes back on. If I turn the car on, red light still on, then move the car even a little, when I try to reset it will go yellow, then almost immediately red when I let go of the button.
This is following a track weekend and one new rear tire. The new tire has maybe 5k fewer miles on it; maybe the minuscule difference in diameter is causing it?
I'll clean the sensors.
Old Wed, Oct-10-2018, 01:41:01 PM   #7
OneFastSicilian
Frankie
OneFastSicilian's Avatar
Italy
mine was off for months, now its back on.. i just ignore it.. as others have said, our TPMS system is BS.
Previous:
  • 01 - AW/IR - Sold
  • 03.5 - IR/Impulse - Sold
  • 02 - TiAg/Blk - Sold
  • 05 - IB/Blk ZCP - Sold
  • 02 - LSB/Blk - Sold
  • 05 - SG/Blk - Current!
Check out my Journal!
*Instagram*
@_Frank_Stone_
Jump to top OneFastSicilian is offline   Reply With Quote
Old Wed, Oct-10-2018, 01:59:16 PM   #8
bosundave
Cut out a small square of 3M black electrical tape and cover the light. I found that 3M seems to leave the least residue and hold up best in heat, unless someone knows of a better tape.
I used to do this on oldy time VCRs that would flash every time the power would hiccup.
Old Wed, Oct-10-2018, 02:11:42 PM   #9
burningchrome
i just ignore it..
This highly offends my sense of organization. I drove around with a SES light for a year and it drove me crazy.
Old Wed, Oct-10-2018, 03:35:29 PM   #10
lmtfi
lmtfi's Avatar
Did you check/equalize the pressure in the new tire with the other rear? What is that pressure?
Did you do the full re-learn procedure in key position 2?
The fact that this follows a new tire installation suggests that you aren't doing the correct re-learn procedure.
Discussing TPMS woes in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
