Old Tue, Oct-09-2018, 06:01:47 PM   #31
rbmwiv
rbmwiv's Avatar
Reputation: 0 rbmwiv is on a distinguished road
Default Re: Will the e46 dsc not accept a 275/35 rear and 265/35 front?!?
It sounds like a bad dsc module if it comes back. The last car I worked on with a similar issue was a 330zhp. It kept throwing abs and dsc codes for the rr wheel sensor. Turned out replacement of the abs module fixed it.
Jump to top rbmwiv is online now   Reply With Quote
Old Tue, Oct-09-2018, 06:07:14 PM   #32
Joshe46
Joshe46's Avatar
Id say thats a possibility, but as soon as stocks go on no issues to be found. A module cant be bad for one set of wheels and now another.
Jump to top Joshe46 is offline   Reply With Quote
Old Tue, Oct-09-2018, 06:57:19 PM   #33
Joshe46
Joshe46's Avatar
Default Will the e46 dsc not accept a 275/35 rear and 265/35 front?!?
Well I put back on stock wheels but this time the rears so 19x9.5 with 275/30 tire and issue went away. However front wheel speed sensor codes stayed. So now Im just lost. Those codes must not be causing the issue unless I just need to drive more for codes to leave.
Old Tue, Oct-09-2018, 08:02:30 PM   #34
SHRMN8TR
Reputation: 0 SHRMN8TR is on a distinguished road
Stretching to help, but in cases like this sometimes you need to follow each sensor and check to make sure there's no dust/dirt/etc? If you can unplug, clean and plug them back? Could be a marginal part and any change (i.e. new wheels) is enough to throw them off?
Jump to top SHRMN8TR is offline   Reply With Quote
Old Tue, Oct-09-2018, 08:03:31 PM   #35
Joshe46
Joshe46's Avatar
I cleaned off the part that goes into hub but not sensor itself. Maybe Iíll give it a shot.
Old Tue, Oct-09-2018, 08:13:35 PM   #36
WALKD_U
WALKD_U's Avatar
Clean the sensor. Junk buildup will cause false readings...
Rides:
2005 AW/IR M3
BMB Stage 4
940whp/765wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
Instagram:
M3HNGRY
EURO.techniks
<a href=https://www.instagram.com/m3hngry/ target=_blank>M3HNGRY</a>
Old Tue, Oct-09-2018, 08:19:37 PM   #37
rbmwiv
rbmwiv's Avatar
Also look into the sensor hole with a flashlight and see that u see the toothed wheel and rotate it to make sure itís clean and if itís got buildup then use some brake klene to get it clean.
Old Tue, Oct-09-2018, 08:21:21 PM   #38
rbmwiv
rbmwiv's Avatar
And make sure that itís the same distance all the way around. And both sides need to match. I have seen the toothed wheels come off and cause a issue.
Old Tue, Oct-09-2018, 08:22:33 PM   #39
Joshe46
Joshe46's Avatar
The rotating part of hub? I saw that. I supose Ill clean again. What should I use to clean electrical sensor part!
Old Tue, Oct-09-2018, 08:25:33 PM   #40
rbmwiv
rbmwiv's Avatar
Brake kleen you can usually just wipe it off with a rag but to clean the electrical plugs with electronics contact cleaner itís at auto parts stores. But yes I have seen the rings on the hubs come off or get lopsided and it wonít read right.
Discussing Will the e46 dsc not accept a 275/35 rear and 265/35 front?!? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
