Old Tue, Oct-09-2018, 05:46:21 PM   #21
ggrslc
Reputation: 0 ggrslc is on a distinguished road
Default Re: Will the e46 dsc not accept a 275/35 rear and 265/35 front?!?
Iím grasping at straws now but could you have a bent wheel thatís just bad enough to piss off your sensor?
Jump to top ggrslc is offline   Reply With Quote
Old Tue, Oct-09-2018, 06:07:19 PM   #22
Joshe46
Joshe46's Avatar
So upon my initial install of the adapters, one was a pain to slip on, turns out i had it cockeyed, so when I rotated wheel by hand it was horribly wobbly. I figured that was my issue but now I did same thing to ensure on properly and they are. These Tes are practically brand new. One didnt even need weights.
Jump to top Joshe46 is offline   Reply With Quote
Old Tue, Oct-09-2018, 06:27:22 PM   #23
rbmwiv
rbmwiv's Avatar
Reputation: 0 rbmwiv is on a distinguished road
The way the speed sensors work is there is a wheel on the inside of the bearing that has slots all around it 3/16Ē and the sensor reads the wheel and gets its readings that way. Can you monitor your speed sensors in real time? If so pull up the two front and see what they read. If they arenít reading anything then the ring has pushed off and needs to get back on. Compare the front to the backs etc. also a picture of the spacers and their hardware would help to diagnose your issue. Itís possible that you have pushed the toothed wheel.
Jump to top rbmwiv is online now   Reply With Quote
Old Tue, Oct-09-2018, 06:44:55 PM   #24
Joshe46
Joshe46's Avatar
Well I read wheel speed sensors through Inpa and all 4 are reading same values, properly. Now really wtff?!
Old Tue, Oct-09-2018, 06:50:29 PM   #25
rbmwiv
rbmwiv's Avatar
And thatís driving? I have no clue what is happening. If you are reading them while itís not moving you wonít see the issue. Can you post a picture of the adapter? Because so far I have never ran into anything like that. But if you didnít check while driving then do that immediately it should up the issue. If all 4 are reading the same then I have no clue why itís throwing front sensors codes. To throw those codes it either has to have a break in the wiring or read different speeds from the rest.
Old Tue, Oct-09-2018, 06:51:25 PM   #26
rbmwiv
rbmwiv's Avatar
Try reading the speeds until the fault occurs.
Old Tue, Oct-09-2018, 06:51:46 PM   #27
rbmwiv
rbmwiv's Avatar
Should help to narrow it down
Old Tue, Oct-09-2018, 06:55:17 PM   #28
Joshe46
Joshe46's Avatar
That was while driving. They are consistent. 0 at stop and so on. Error code doesnít go away. I clear and itís already there. I checked all wiring and no issues there. Im truly at a loss of what the car isnít liking. Dont really have other pics of adapters, but this is the adapter mounting bolt next to oem lug.
Old Tue, Oct-09-2018, 06:57:37 PM   #29
rbmwiv
rbmwiv's Avatar
I am also at a loss so when you clear the codes it comes back immediately?
The adapters look like they shouldnít be a issue.
Old Tue, Oct-09-2018, 06:58:55 PM   #30
Joshe46
Joshe46's Avatar
I clear it with my code reader and its right back. I cant access dsc or tpms with my inpa because I think i need a bridges dcan. I just have a ttfs one.
Discussing Will the e46 dsc not accept a 275/35 rear and 265/35 front?!? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
