Old Thu, Oct-11-2018, 10:15:56 PM   #11
tjkenny15
tjkenny15's Avatar
Default Re: Anyone have kw v2 Coils, thoughts?
Originally Posted by Paulo M View Post
Yep, Iíd rather have kw spec it for me than my noob ass try again.
When I adjusted the v2ís, I couldnít tell if things were getting better or not. I set at the middle and was happy.
Ok I get where you're coming from. Either way, sounds like the KWs would be superior with their warranty benefits. Maybe I'll be able to pick up a nice set of V1s or V2s over Black Friday or Cyber Monday. I can't remember if I saw them go on sale last year or not.
If I could find a great deal on a set of Bilstien PSSx, I may consider them, as well.
Thanks for the input
2005 BMW M3 INDIVIDUAL - Estoril Blue
Jump to top tjkenny15 is offline   Reply With Quote
Old Thu, Oct-11-2018, 10:17:11 PM   #12
tjkenny15
tjkenny15's Avatar
Originally Posted by Mars View Post
I've been running the KW V2's for four years now. I daily drive my car and have no complaints.
Did you consider any other coilover setup at the time of purchase?
Old Thu, Oct-11-2018, 10:39:34 PM   #13
bosundave
Reputation: 0 bosundave is on a distinguished road
I ran them, bc coilovers-kwV2-low mileage stock, all within 1 month. KW was very comfortable, at much lower height compared to stock. It was more comfortable than the China bcís but felt more direct. Canít go wrong with these for street use. My next coilovers will most likely be kwV1.
I had the exact same experience.
But I am now moving to linear SWIFT coil springs and TC Kline SA Koni proprietary shocks. My TCK plates have mono ball spherical bearing. Same for the BCR's
I had Turner camber plates with the KW's and Buna N rubber mount. I am not a fan of spherical bearings in the street.
But maybe with the SWIFT springs (448 lbs) up front, my ride may turn out to be great. I hope so.
I will post a thread when I do this. Rotors first for my Brembos. Then the TCK installation.
Have you considered TCK with Linear Springs? Particularly the SWIFT springs?
I always thought of my KW V2's as "learner" coilovers. I did like the very much, however.. I wish I had the TCKs installed to compare them for you.
I wasn't speeding...I was QUALIFYING!
Agency Power muffler , Ebay midpipe, Magnaflow resonators BREMBO GT BBK, Endless Racing brake pads , TC Kline SA Coilover (front) Swift 448lb springs, BC Racing coilover rears (for now), TMS front(30mm) and rear(25m) adjustable anti sway bars, AKG FCABS, TMS limiters on AKG RTABs, and powerflex subframe bushings, HPF AND TMS weld in Subframe kit, 10 hours of additional subframe Stitch welding above and beyond what's usually called for, CF trim interior and exterior clear coated by my guy with heavy duty UV protection, Vorsteiner CF rear diffuser, Strassentech type CF lip, Aurora Angel Eyes, DRL,HID Fogs 6k, Headlights HID 6k, D-Force racing wheels sandblasted and powder-coated semi-gloss black, Square set up 265/35-18, built-in Passport Escort 9500CI .. custom mount of controls in ash tray, , rareQuatro CF shock tower brace, Pioneer Avic Z3, BSW stg 1speakers, BSW sub
Jump to top bosundave is offline   Reply With Quote
Old Thu, Oct-11-2018, 10:52:50 PM   #14
Paulo M
I like the simplicity of KW’s to be honest. I don’t want to get in too deep, picking out springs etc. That, and I’m honestly not the best judge of quality coilovers feel like some of you guys are. Rather have KW give me their representation of a good street setup than me pretending to know what I’m looking for and potentially going over my head.
BREMBO BBS DIXIS
Old Thu, Oct-11-2018, 11:36:41 PM   #15
aerpelding
///M Driver
aerpelding's Avatar
Reputation: 0 aerpelding is on a distinguished road
Originally Posted by tjkenny15 View Post
Are you looking at the KW v1s because you dont see the benefit of the kw v2s dampening adjustment capabilities?
KW V2's only adjust rebound, not dampening. So that's one thing to keep in mind.
I went V1, and actually regret not going v2 mainly for the rear. I have the v1's lower than recommended and the rebound in the rear is too soft imo. They still ride great and i absolutely love them, but i'd go v2 if i were to do it again. I may actually upgrade to v2 in the rear when the v1's go bad.
But again, my ride height has a lot to do with it. If they were raised up a bit the v1's would be absolutely perfect.
-Aaron
www.instagram.com/htown_lsb_m3/
Laguna Seca Blau | Full Cinnamon Interior Swap | KW v1 | GC Street Camber plates | OEM e92 19" ZCP w/10mm Macht Schnell rear spacers | 245/35, 275/30 Michelin PSS | OEM 330d shifter | ZHP Leather weighted shift knob | Ledermanz Alcantara wrapped steering wheel | Coby Alcantara e-brake handle & Alcantara e-brake boot | Macht Schnell intake elbow | Macht Schnell air filter | OEM Fender Gills painted Gloss Black via iND | OEM Hood Grills painted Gloss Black via iND | OEM LED Taillight retrofit | Bi-Xenon D2S 4.0 Projector retrofit by Kustom54 Lighting | Streamline CF CSL Style rear diffuser | SuperSprint LTW Race |
Jump to top aerpelding is online now   Reply With Quote
Old Thu, Oct-11-2018, 11:59:21 PM   #16
oceansize
Kwisatz Haderach
oceansize's Avatar
FYI, I will be posting a used set of KW v2 with less than 3,500 miles for sale tomorrow. I moved to GC was because I'm in a vert, which is considerably heavier, an need higher spring rates. Otherwise they are a nice all-around simple solution. I would not recommend these for a vert owner as KW doesn't differentiate their springs for vert vs coupe.
2003 M3 Convertible SMG w/Hardtop | GC Coilovers and Camber Plates | ESS VT1-475 Gen 3 Supercharger | Stoptech Brakes
Apex ARC-8 19" Hypersilver | CSL SMG (and 255) Tune | Rogue Eng. Diablo Exhaust w/ SS Tips | Rogue Eng. Rasp Pipe
Storm Motorwerks SMG Paddles | Two Tone Grey/Black Interior | Alcantara E-brake Boot
Very Recent Maintenance: FCABs | FCAs | RTABs | Motor Mounts | PS Hoses | Inner/Outer Tie Rods | End Links | Vanos Solenoid | Fan Clutch | Trans Fluid | Diff fluid
Old Mon, Oct-15-2018, 10:12:06 PM   #17
11b4
11b4's Avatar
So now that ecs lowered the bilstein price again should I pony up the extra $200 and get the pss10 or just get the KW? It's a street car
Jump to top 11b4 is online now   Reply With Quote
Old Mon, Oct-15-2018, 10:47:34 PM   #18
I'd only get the PSSs for their dampers, and run linear springs. If you're not going to do that, KW is good.
_
OE CSL trunk Sportline 8S 18"x8.5/9.5" + 10mm spacers MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack Pioneer/CDT/Eclipse/Kicker
Old Mon, Oct-15-2018, 11:27:55 PM   #19
tjkenny15
tjkenny15's Avatar
I'm in the same boat exploring my suspension options.
Top contenders at the moment:
1) PSS10 with Swift linear springs 9k front, 11k rear
2) Fourtune Auto 500 with linear springs 9k front, 11k rear
3) KW V2s
4) BC Racing coilovers
Oddly, I'm leaning more towards the Fourtune Auto coilovers w/ swift springs. And as a budget second choice, BC Racing coilovers... but I don't know if I could ACTUALLY put them on my car being Taiwanese.
I like the KW V2s because the warranty and I could see these going on sale over Black Friday.
Ugh too many decisions
Old Tue, Oct-16-2018, 01:34:12 AM   #20
Paulo M
Rule out the bc’s bro, just do it right the first time. KW and Bilsteins are the only choice for me from your list.
BREMBO BBS DIXIS
Discussing Anyone have kw v2 Coils, thoughts? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
