Old Mon, Oct-08-2018, 02:36:11 AM   #1
sivikvtec
Reputation: 0 sivikvtec is a jewel in the rough
Default Did some maintenance today, do my cams and plugs look normal?
I replaced my valve cover gasket and plugs today, I noticed some wear on the camshafts and the threads on the spark plugs were gunked up with oil.
The car has around 87k on it, does this look normal? There wasnít any oil in my spark plug wells, and from what I can tell the valve cover gasket wasnít actually leaking. I think the plugs had around 35k on them.
Iím pretty sure I had oil consumption caused by a bad oil seperator a few years ago if that matters..
Jump to top sivikvtec is offline   Reply With Quote
Old Mon, Oct-08-2018, 04:11:02 AM   #2
Default Re: Did some maintenance today, do my cams and plugs look normal?
Typical wear. Nothing to worry about.
Old Tue, Oct-09-2018, 12:32:09 AM   #3
omairtheman1
Looks fine. Good amount of silver let's you know that you're changing the oil often enough.
Discussing Did some maintenance today, do my cams and plugs look normal? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
