Old Wed, Oct-10-2018, 08:33:19 PM   #11
NolliM3
NolliM3's Avatar
Default Re: Black Tar Looking Adhesive
Just to update the thread, O'reily claimed they don't sell the butyl tape anymore and that I should check Home Depot for the 3M Strip Calk.
Old Wed, Oct-10-2018, 09:10:26 PM   #12
Yes they do.
https://www.oreillyauto.com/shop/b/c...6/130050ea5127
Old Thu, Oct-11-2018, 02:58:08 AM   #13
NolliM3
NolliM3's Avatar
Well, I went to Home Depot and they had the Butyl tape for $5.90 including tax for 50yds...they only had the gray one...I bought it.
Old Thu, Oct-11-2018, 09:41:31 PM   #14
NolliM3
NolliM3's Avatar
Thank you Brett for recommending the tarminator...it really clean it up very well and I haven't even wipe it with the alcohol yet. Also, how do one remove that clip/lock in the green circle? I need to change the bushing that connect the window motor to the regulator...see pic below.
Old Thu, Oct-11-2018, 10:24:14 PM   #15
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
A 5mm allen key. Its head is on the inside.
Old Fri, Oct-12-2018, 01:40:36 AM   #16
NolliM3
NolliM3's Avatar
Thank you M_Parallel...I would never have thought that...I'll put some loctite on when I put it back together because that's where I believe I have an annoying rattle...
Old Fri, Oct-12-2018, 10:51:58 AM   #17
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
On my 328i the 4 rivets holding the motor to the door were loose. Drilled them all out and fitted proper nuts, bolts and washers. This was over 10 years ago. They still hold today and removing the whole assembly is a breeze now.
Old Thu, Oct-25-2018, 04:20:26 AM   #18
Brent S
Reputation: 0 Brent S is on a distinguished road
Please try this before wasting money on a new window motor. Take the motor off the door and take it apart. Clean the commutator, it's the area on the armature that comes into contact with the brushes, with emery cloth or very fine grit sandpaper. My passenger motor went dead and worked like new after I did this. These motors do not work enough to wear out. I suspect that commutator surface oxidizes resulting in "Dead spots" that prevent the brushes from working.
Jump to top Brent S is offline   Reply With Quote
Old Thu, Oct-25-2018, 05:56:59 AM   #19
NolliM3
NolliM3's Avatar
Thank you Brent S, for responding...yes, I have learned the hard way, except it was a used motor instead of new. That was what I had expected after buying the used motor and discovering that nothing was wrong with the old motor. Parts (the bushing and clips) are on the way.
Discussing Black Tar Looking Adhesive in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
