Old Thu, Sep-27-2018, 02:20:26 PM   #21
white-hot
is lurking around the corner
white-hot's Avatar
Default Re: NA E36
Originally Posted by pbonsalb View Post
With a lot of hard work, a 325i can be reinforced. The reinforcements are available. M3 and 338 have done heavier duty parts but they can be added or swapped. Again more work. But even the last M3 is 19 years old and probably needs a lot of work. It may have a tired LSD that probably needs rebuilding, and a ZF320 that will handle power better than a Getrag 250 but probably needs shift detention bushings and rear subframe chassis reinforcements, but it still needs rtab pocket and front subframe reinforcements. You will be doing a lot of work to any of these cars.
All true of course. Just a waste of money to do so much to only bring a 325 up to the standard of a worn-out M3, and that is before you even touch the engine. It is a lose-lose in my opinion.
Old Thu, Sep-27-2018, 04:18:14 PM   #22
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Default Re: NA E36
What do S54’s go for these days?
Old Thu, Sep-27-2018, 04:25:30 PM   #23
Default Re: NA E36
After paying for everything needed to install in an E36 or sitting on a pallet?
Old Thu, Sep-27-2018, 06:10:13 PM   #24
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Default Re: NA E36
Just the engine and needed ancillaries.
Fitting costs are variable so wanted to exclude that.
Old Thu, Sep-27-2018, 07:57:55 PM   #25
M-technik-3
Default Re: NA E36
Depends on area and mileage if you use www.car-part.com
Have seen them as low as 1200 and as high as 6000 in last few months. S54 is not gonna get him tp the level he wants plus what appears to be shoe string budget limits things.
I live on ramen some days when needed lol.
Old Thu, Sep-27-2018, 07:59:11 PM   #26
twentyseven
@itsmejonnyv
twentyseven's Avatar
Default Re: NA E36
Any E36 engine conversion that costs less than $10k generally means corners were cut. It's just not realistic to do it properly for less.
V-CSL, BBS CH, Öhlins R&T, Supersprint, Brembo GT, custom Z4M seats, AVIN, G5R projector swap
Jump to top twentyseven is offline   Reply With Quote
Old Fri, Sep-28-2018, 07:17:54 PM   #27
JJCTHE1
JJCTHE1's Avatar
Reputation: 0 JJCTHE1 is on a distinguished road
Default Re: NA E36
Is your M50 in an M3? (I hope not). If not, you are on the wrong forum.
Jump to top JJCTHE1 is offline   Reply With Quote
Old Tue, Oct-02-2018, 06:30:41 PM   #28
Nate047
Nate047's Avatar
Default Re: NA E36
nitros and ebay turbo setup.
Old Tue, Oct-02-2018, 07:24:21 PM   #29
spaghettiM3
spaghettiM3's Avatar
Reputation: 0 spaghettiM3 is on a distinguished road
Default Re: NA E36
Don't forget overnight parts from Japan.
Insta @DaytonaViolet283
Jump to top spaghettiM3 is offline   Reply With Quote
Old Tue, Oct-02-2018, 11:23:43 PM   #30
Default Re: NA E36
Originally Posted by fattycharged View Post
ron frum
got tha ill comunikashin
Originally Posted by twentyseven View Post
4k budget is a joke. My advice is not.
Glad I stopped in here today
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · zero options · ~3200lbs · JOURNAL
_
Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · Supersprint V1 stepped 2.5" · SS V1 S pipes 2.5" + 200 cell HFC · OE sect 2 · SCZA 2.5" sect 3 · Besian · RE pullies · WPC'd OE bearings · oil catch can · fan/SAP/washer delete · CSL battery
GroundControl S/A Koni (Hyperco/Eibach 300/600) + tall RSMs · Hotchkis front sway (med) · rear strut bar · TMS camber & subframe plates · Eibach alu rear camber arms · RE trans mounts · AKG poly subf/diff 95a · SDW RTAB · weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing · Mason clutch pedal + brass bushing · TMS black pedals · delrin brake pedal bushing
OE CSL trunk · Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · APEX 75mm Studs · Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL · ZHP "712" rack · Pioneer/CDT/Eclipse/Kicker
Discussing NA E36 in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
