Old Tue, Sep-25-2018, 04:11:24 AM   #1
NolliM3
NolliM3's Avatar
Default Help Me Fix My AC Woes
My AC has been blowing hot air mixed with the cold air...during the summer it becomes pointless to run the AC. There is no problem during the winter getting heat. I have diagnosed my AC with DIS and got the following see pics below. So after taking things apart to see as well as with the diagnoses, I am concluding that maybe my AC control unit might be bad...does this conclusion makes sense? The unit #64118391512 is no longer available, and I would need to visit the junkyard. I say the control unit because the diagnoses points to the white plug pin 10/12 and the blue plug pin 13/14. I also provide the electrical diagram of the Integrated Climate Regulation.
Old Tue, Sep-25-2018, 04:34:48 AM   #2
Eric M3
shogun
Eric M3's Avatar
Reputation: 0 Eric M3 is on a distinguished road
Japan
Default Re: Help Me Fix My AC Woes
Did you already check the wires? It says wire from SG = in German Steuer Geraet = control panel to component or component itself faulty.
instead of the NLA control panel you can also check fot the older version
Part Cross-reference 64118391512 Uncoded control unit for air conditioning
From: 06/22/1992 To: 02/09/2012 (ENDED) Weight:0.231 kg Price:$440.30
Supersedes: 64111466581 12/18/1992 —
Programa also offers reman units http://www.programainc.com/item_list.aspx?idcategory=28
My 7 series DIY site: http://twrite.org/shogunnew/topmenu.html
Jump to top Eric M3 is offline   Reply With Quote
Old Tue, Sep-25-2018, 05:25:48 PM   #3
NolliM3
NolliM3's Avatar
Thank you Eric M3 for responding and clarifying what the SG meant...it had been baffling me. Yes, I checked the connection and it's solid...that's why I concluded it most be the control panel. I had also checked RealOEM...it doesn't show for my car as my car was manufactured, 10/1995 and the control panel #6411839152 ended 9/1995 yet; that's what my car has. I also discovered Programa yesterday.
Discussing Help Me Fix My AC Woes in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
