Old Fri, Sep-21-2018, 07:33:48 PM   #1
Default Gauging interest in a trans tunnel insulation sag fix
Transmission tunnel insulation braces have been completed and are now ready to be sold.
Old Fri, Sep-21-2018, 09:38:56 PM   #2
GG///M3
LOUNGE CREATOR
GG///M3's Avatar
Reputation: 0 GG///M3 is on a distinguished road
Albania
Default Re: Gauging interest in a trans tunnel insulation sag fix
Pretty fancy idea
Jump to top GG///M3 is offline   Reply With Quote
Old Fri, Sep-21-2018, 10:06:48 PM   #3
cblock
cblock's Avatar
Hell ya!
Cblock
Jump to top cblock is online now   Reply With Quote
Old Fri, Sep-21-2018, 10:53:18 PM   #4
craigjimc
Reputation: 0 craigjimc is on a distinguished road
Sign me up for a set!
Jump to top craigjimc is offline   Reply With Quote
Old Fri, Sep-21-2018, 11:00:55 PM   #5
Blaikenstein
Blaikenstein's Avatar
Reputation: 0 Blaikenstein is on a distinguished road
Good work on creating a solution!
I cut mine and it looks like crap but Iím planning on doing gold tape through the area into the engine bay.
Jump to top Blaikenstein is online now   Reply With Quote
Old Sat, Sep-22-2018, 01:55:25 AM   #6
omairtheman1
I'd buy one.
Old Sat, Sep-22-2018, 01:56:36 AM   #7
This is great for those who want a fix with the trans installed. If the trans is out, I recommend removing the old disintegrating factory insulation that rains fibers in your eyes if you touch it with DEI or similar stick on fiberglass heat reflective tape or sheets — I have used both and they work great. If you just remove the insulation and put nothing in its place, you may feel heat through the tunnel in hot weather though there is insulation under the carpet inside that limits the intrusion. If you use a heavy replacement rather than the thin stick on, such as the thicker aluminum sheets made for tunnels, you will have little clearance for the trans. I love the ease with which I can reach the trans bolts or remove and install the slave with the DEI style tape or sheets. But for most, that is not an issue since you wont be doing those jobs often — I have broken a couple of trans and fused a couple of clutches due to excess power (500+ lbs rear wheel torque from turbo S52).
Old Sat, Sep-22-2018, 02:31:08 AM   #8
Great options pbon. I ran for 4 years with mine completely removed. Made transmission work such a breeze. The next rendition of my 96 a new OEM insulation is already on hand.
Old Sat, Sep-22-2018, 04:05:00 AM   #9
Oogie_M
o_O
Oogie_M's Avatar
Reputation: 0 Oogie_M is on a distinguished road
Taiwan
Sign me up. You get so used to staring at the insulation touching the guibo that it starts to look normal (until you realize how much itís sagging).
Jump to top Oogie_M is offline   Reply With Quote
Old Sat, Sep-22-2018, 04:24:30 AM   #10
SQ13
I thought I was dealing with a unique problem, but no, there are many of you!
Definitely interested. It was really frustrating when I had to give up and let the insulation continue sagging.
Discussing Gauging interest in a trans tunnel insulation sag fix in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
