Old Wed, Sep-19-2018, 12:59:52 AM   #1
sivikvtec
Reputation: 0 sivikvtec is a jewel in the rough
Default Does anyone here use OEM SAF-XJ Diff Fluid
I don't want to experiment with non-oem fluids in the diff if I can avoid it. Does anyone here actually run the OEM 83-22-2-282-583 (SAF-XJ) fluid?
On ECS's website, they say its NOT compatible with the E36 M3, which is making me second-guess it.
I tend to trust OEM fluids the most (maybe i'm an idiot), so would like to use this stuff if it makes sense. From the best that I can tell BMW only sells the original diff fluid by the barrel or something.
Jump to top sivikvtec is online now   Reply With Quote
Old Wed, Sep-19-2018, 01:52:09 AM   #2
Default Re: Does anyone here use OEM SAF-XJ Diff Fluid
E46 M3, yes... only OEM fluids. The differential and trans are very picky.
E36 M3, no. I run redline or whatever is of quality available to me. It’s not as critical for us. I do prefer Castrol and Pentosin products though.
Old Wed, Sep-19-2018, 03:00:14 AM   #3
sivikvtec
Cost aside, I'm wondering if there's any risk the SAF-XJ fluid will tear up my diff. I'm not sure that I would trust the answer from the local dealer.
Old Wed, Sep-19-2018, 03:48:00 AM   #4
I believe the concern is actually too much slip allowed with a clutch style LSD. I do not think tearing up the diff is a worry to have.
Old Wed, Sep-19-2018, 02:16:52 PM   #5
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Castrol Syntrax 75w-140 for E36 clutch LSD and you’ll be fine.
Old Thu, Sep-20-2018, 05:19:57 AM   #6
Hasan Shaikh
Reputation: 0 Hasan Shaikh is on a distinguished road
United Arab Emirates
I use OEM SAF-XJ FM Booster Diff Fluid in my car.
Jump to top Hasan Shaikh is offline   Reply With Quote
Old Fri, Sep-21-2018, 12:26:09 AM   #7
frbz
If your car is a 3.2 then it has a different diff from the NA spec cars.
Jump to top frbz is offline   Reply With Quote
Old Fri, Sep-21-2018, 02:50:11 AM   #8
sivikvtec
I ended up going with the BMW SAF-XJ fluid without the FM booster, p/n 83-22-2-357-992
https://www.getbmwparts.com/oem-part...xj-83222357992
I assume it's the same as the Castrol SAF-XJ, but I was already buying quite a few things from getbmwparts so just bought it there.
Old Fri, Sep-21-2018, 03:56:27 AM   #9
Hasan Shaikh
Yes. I have a 3.2
Discussing Does anyone here use OEM SAF-XJ Diff Fluid in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
