Old Sun, Sep-16-2018, 05:34:57 PM   #1
JitteryJoe
Default Wonky fuel trims levels
I'm still chasing down fuel trim problems. All the injectors were pulled and resealed (there was some leaking around the seals). The O2 sensors are new and correctly installed. The ICV is new. Fuel pressure at correct level. The long term trim levels are zero.
The short term are very strange (negative on one bank, positive on the other).
The car won't hold an idle. The trim levels don't seem to change at higher RPMs.
Bad injectors? Possible cams are not aligned properly? Thoughts?
Thanks!
Joe
Jump to top JitteryJoe is online now   Reply With Quote
Old Mon, Nov-19-2018, 05:47:37 PM   #2
JitteryJoe
Default Re: Wonky fuel trims levels
How to drive yourself nuts? Just reverse the forward O2 sensors connectors at the fuel rail wiring harness.
Discussing Wonky fuel trims levels in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
