Old Tue, Oct-02-2018, 02:42:10 PM   #21
bigjae1976
Default Re: Any S54 Rebuild Tips/Advice?
Failing better info, I would follow BMW's recommended S54 break in procedure. Certainly they had the most info on the engine, and I can think of no motivation/incentive for them to give a bad or sub optimal break in procedure.
So, <5500 rpm, <100 mph, < 75% throttle, varied RPM for 1200 miles, followed by a fluid swap.
100% agree
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Tue, Oct-02-2018, 03:14:04 PM   #22
KS Golfer
Reputation: 0 KS Golfer is on a distinguished road
if i had a rebuilt S54 i'd be following the factory guidelines as well, but add in that initial oil change to clean up any debris.
Jump to top KS Golfer is offline   Reply With Quote
Old Thu, Oct-04-2018, 12:55:22 AM   #23
digger
Bmw recommend a breakin after doing rod bearings to, just saying.....
1996 e36 M3 Evo
Jump to top digger is offline   Reply With Quote
Old Thu, Oct-04-2018, 06:55:38 PM   #24
BearDeXPS
BearDeXPS's Avatar
first drive after re-build... my engine/clutch was ripped on haha
Old Thu, Oct-04-2018, 11:02:08 PM   #25
T3AMFiSh
Your mom goes to college
T3AMFiSh's Avatar
i followed Lang's break in,
Old Thu, Oct-04-2018, 11:09:22 PM   #26
bigjae1976
Is that a recommendation on the BMW procedure? Or does the dealer just tell you that?
Old Sat, Oct-06-2018, 03:03:13 AM   #27
black bnr32
Reputation: 0 black bnr32 is on a distinguished road
Use some gasket maker on the valve cover gasket
Get the injectors cleaned?
Jump to top black bnr32 is offline   Reply With Quote
Old Sun, Oct-07-2018, 02:59:48 AM   #28
GeorgeH
BMW Fan
Reputation: 0 GeorgeH is on a distinguished road
That is the BMW recommended procedure for new engines AND after a rod bearing replacement. IIRC they supplied a new sticker and we would write in the mileage when the 1200 miles was up.
Current BMW stable: '00 R1100S, '09 HP2S, '12 R1200GSA, '00 323iT (S54 Swapped), '00 332iT (stock), '03 325iT (stock), '04 ZHP Imola/6MT (basic suspension mods)
Jump to top GeorgeH is offline   Reply With Quote
Old Sun, Oct-07-2018, 03:36:07 PM   #29
GeorgeH
BMW Fan
I actually just checked as I have the SI B11.04.04 Service Action: Rod Bearing replacement here with me.
"Following completion of this Service Action, the following engine break-in instructions must be observed by customers: for the first 1,200 miles engine speed should not exceed 5,500 RPM or road speed should not exceed 105mph.
Engine oil service is NOT required after the completion of the engine break-in period."
Old Mon, Oct-08-2018, 09:46:33 PM   #30
bigjae1976
Thanks!
engine rebuild, m3 rebuild, s54 headgasket, s54 rebuild
Discussing Any S54 Rebuild Tips/Advice? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
