Old Sat, Jan-20-2018, 07:34:50 AM   #41
scoopy128
Reputation: 0 scoopy128 is on a distinguished road
Default Re: Obioban's Avin Avant 3 thread (eventually DIY to delete all stereo modules/harnes
Was able to install mine however i cant connext to google play and i dont know jow the apple car play works and dont know where to plug that it i have 2 extra usb alot there
Jump to top scoopy128 is offline   Reply With Quote
Old Sat, Jan-20-2018, 01:20:39 PM   #42
scoopy128
Thanks was able to download the apk now i was able to download spotify waze and google movies.
Just a question, do you guys notice the hissing or static sound in bluetooth? Also my time in the radio keeps on reseting
Old Sat, Jan-20-2018, 03:37:52 PM   #43
icecream
Registered Apples
icecream's Avatar
Originally Posted by icecream View Post
Just an FYI:
For brightness I used pin 1 on the blue harness labeled "nachtbeleuchtung". Worked perfect.
Still cannot get Bluetooth to stream without error. Sounds like when you walk away too far from the phone and your earbuds start tapping out. I'm gonna get a hold of tommy and see what's up.
Edit. Also cannot get it to communicate with ibus, not sure why.
For ibus I didn't have the usb plugged in from the main harness. That should fix that.
Also my Samsung Bluetooth seems to work ok, my lgv20 does not.
Did you update the APK? Also Avin has an update that fixes that. Email them for it.
No hissing that I can remember. Ask them for the update, may fix some issues.
Also, how did you plug in your unit? Is it a custom harness or one they supplied?
Old Sat, Jan-20-2018, 05:05:51 PM   #44
scoopy128
One that they supplies with the 6m long harness. And i have a couple of antenna left there. Theres an antenna ehere i removed the green part so i can hook it up at the back of the radio (radio antenna)
Old Sat, Jan-20-2018, 05:14:01 PM   #45
m3 hal
If you remove the nav option code, it'll just look for the standard radio instead which will give the same issue.
Did the CSL have any special coding for this since it was available without a radio?
Old Sat, Jan-20-2018, 05:58:53 PM   #46
cosmos///m3
MMMmmmmmm....
cosmos///m3's Avatar
Reputation: 0 cosmos///m3 is on a distinguished road
Sorry being late to the party here... Im curious if this has been discussed here or any of the other Avin threads. One of the "issues" on the older unit was volume. I would max the unit out and sound was very low still. Any idea if this newer unit resolves that? I know its still early, but any quirks found etc?
2005 ZCP Schwarz II/Imolarot 6spd ///M3 ||| 1999 Estoril Blau/Estoril Blau ///M Coupe "Clownshoe"
2014 Alpinweiss Uni/Mokka X5 ///M Package (wifey)
Originally Posted by hum3a
man i need a fu<kin wife to run errands for me......fu<k grocery shopping
Jump to top cosmos///m3 is offline   Reply With Quote
Old Sat, Jan-20-2018, 06:37:41 PM   #47
If anything it's too loud. Depending on what's playing I keep the volume anywhere between 8 and 12 (out of 100 I think)
European cars in general can remove the radio option code and have everything work. US cars default to having a radio even if all option codes are removed, so diagnostic software will still look for it.
Old Sat, Jan-20-2018, 08:07:06 PM   #48
Any reason to not tweak the VO to be a European car to have ours act that way?
Old Sat, Jan-20-2018, 08:10:33 PM   #49
More trouble than it's worth. It only makes a difference when hooking up to dealership diagnostic / programming software, which isn't an issue for most of us.
If a European VO is present, and the dealership software wants to recode module(s) to default, then it'll go to the European defaults (metric units, german language, european lighting settings, and so on).
Old Sun, Jan-21-2018, 12:35:37 AM   #50
icecream
Registered Apples
icecream's Avatar
Got it, there is a standby timer setting in the options menu. It is probably on 0.
Sorry OP. This thread took a life of its own, hope you don't mind.
Discussing Comprehensive Avin Avant 3 Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
