Old Fri, Jan-12-2018, 12:25:31 PM   #31
scoopy128
Reputation: 0 scoopy128 is on a distinguished road
Default Re: Obioban's Avin Avant 3 thread (eventually DIY to delete all stereo modules/harnes
If you remove the nav option code, it'll just look for the standard radio instead which will give the same issue.
Oh ok thanks hopefully i will be able to also install then tomorrow. So now you guys are experiencing what problems? Bluetooth disconnects once in awhile? (U guys use bluetooth for music or for calls?)
Jump to top scoopy128 is offline   Reply With Quote
Old Sat, Jan-13-2018, 01:05:25 AM   #32
If the nav unit initiates the BT connection, it seems to suddenly disconnect around 30 minutes into the drive. If I initiate the connection from my phone, it works fine seemingly indefinitely. Not sure if the bug is with the Avin or my phone on that one. I haven't hooked up the microphone yet, so I haven't tested phone calls
On another note, I went ahead and wired up my factory GPS antenna (which I had because my car came with BMW Assist) to the Avin - it works, and the signal is pretty strong (getting a fix on 10 satellites in my garage). As mentioned before, the GPS connector for the BMW Assist module is different than what navigation cars got, so the adapter Avin sells won't work.
Old Sat, Jan-13-2018, 01:12:41 AM   #33
icecream
Registered Apples
icecream's Avatar
Originally Posted by scoopy128 View Post
Oh ok thanks reason i ask because when im using my ista if i dont see the navigation in my radios menu it takes like 15 mins to scan my car and read all the modules and it will show a nav error. But sometimes if my nav is working it can finish the scan in just like 2 mins hehe
Is Ista another name for DIS? If it has the same interface you can scan only the modules you want by first selecting no to running tests when it prompts you and deselecting everything before scanning or "testing modules". My terminology might be off but if it's the same, you know what I mean.
Old Sat, Jan-13-2018, 01:24:58 AM   #34
Ista is the latest diagnostic suite from BMW. It wants to attempt finding all the modules the car has before it lets you do much of anything else.
Old Sat, Jan-13-2018, 01:52:51 AM   #35
icecream
Registered Apples
icecream's Avatar
Ah, got it. I thought he meant he was waiting for it to scan for errors.
Old Sat, Jan-13-2018, 11:15:32 AM   #36
scoopy128
Only with bmw assist that you have a gps antenna? I have a block box thingy in my windshield and a mircrophpne in the pillar. The owner told me he didnt add that they came out from the dealer with that
Old Sat, Jan-13-2018, 01:44:59 PM   #37
As far as I know, yes. I can't say for sure without seeing what you have, but it sounds like those things are aftermarket to me.
Old Mon, Jan-15-2018, 11:27:18 PM   #38
Originally Posted by zkc View Post
Also, Avin says an update will hopefully be out this weekend.
Did you end up getting an email about any sort of update?
On another note, regarding the factory GPS antenna, it does seem to work better. It gets a GPS fix quicker, and the speedometer reading in Waze is more stable (before it would jump around by 2-3 mph with cruise on, now it's more or less solid). I don't know if this is because the antenna is actually any better or if the rear deck is simply a better location (I'm betting it's mostly the latter).
Old Wed, Jan-17-2018, 02:22:21 AM   #39
icecream
Registered Apples
icecream's Avatar
Just an FYI:
For brightness I used pin 1 on the blue harness labeled "nachtbeleuchtung". Worked perfect.
Still cannot get Bluetooth to stream without error. Sounds like when you walk away too far from the phone and your earbuds start tapping out. I'm gonna get a hold of tommy and see what's up.
Edit. Also cannot get it to communicate with ibus, not sure why.
Old Wed, Jan-17-2018, 11:34:29 PM   #40
L0ADED
L0ADED's Avatar
Default Obioban's Avin Avant 3 thread (eventually DIY to delete all stereo modules/harness)
Can someone post a video showing the various functions when they have it all setup? Looking forward to seeing Waze work with Android Auto. Waze works great on the 4100NEX I have in my other car.
Discussing Comprehensive Avin Avant 3 Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
