Old Tue, Jan-09-2018, 11:46:43 PM   #21
Default Re: Obioban's Avin Avant 3 thread (eventually DIY to delete all stereo modules/harnes
I have no idea about Android Auto, but for the Play Store you need to reinstall/update the Play Services. Click on this link from your head unit, download the apk, and install it: https://www.apkmirror.com/apk/google...-apk-download/
Old Wed, Jan-10-2018, 12:57:56 AM   #22
icecream
Registered Apples
icecream's Avatar
My BT cut out once about half an hour into a drive. Connection seemed good and then it suddenly disconnected. Will have to see if it keeps doing that. I saw this old post on Apple's support forums where the one user found it disconnects if the head unit initiates the connection, but stays connected if the phone initiates the connection. I did reconnect from the phone, so i wonder if that's why it didn't cut out again. If that's the case I wonder where the issue lies: my iPhone or the Avin
If the wifi and Bluetooth share antennas, maybe I need a more optimal location (though the wifi signal was really strong; -27dB)
I installed this apk: https://www.apkmirror.com/apk/google...-apk-download/
APK worked, thanks.
My Bluetooth still cuts out constantly. I do not have the FM antenna hooked up still but unless they share the antenna which I doubt, I don't know what the issue is. Also, I only have the remote 12v and direct 12v hooked up. There is one pin on the harness for "12v ant out" but I am hesitant to apply 12v to it unless I know what it's for.
Maybe the update from Avin will address it.
Old Wed, Jan-10-2018, 01:20:57 AM   #23
I don't think it uses the FM antenna. It either shares the wifi antenna or is internal.
Let's see what that update holds. Hopefully having that package can give us a little insight into how to hack these things too. Really hoping it's possible to restore complete bluetooth functionality like on the Intel Joying units.
Old Wed, Jan-10-2018, 01:24:48 PM   #24
zkc
zkc's Avatar
Reputation: 0 zkc is on a distinguished road
Thanks for the APK, Play Store now works.
Now onto the Android Auto...
Jump to top zkc is offline   Reply With Quote
Old Wed, Jan-10-2018, 01:39:31 PM   #25
I would LOVE to have bluetooth tethering work. Absurdly vastly superior to wifi or USB tethering.
Old Fri, Jan-12-2018, 01:50:37 AM   #26
scoopy128
Reputation: 0 scoopy128 is on a distinguished road
Just a question guys, if u have the nav package etc and you are removing the cd and nav system do you have to recode it and remove the nav package?
Jump to top scoopy128 is online now   Reply With Quote
Old Fri, Jan-12-2018, 02:18:32 AM   #27
icecream
Registered Apples
icecream's Avatar
I don't see why bothering. I did not code mine out.
Unless you don't want DIS catching any errors but that doesn't affect anything.
Old Fri, Jan-12-2018, 03:21:41 AM   #28
You shouldn't have to recode anything. There is a function in the climate control panel that apparently has something to do with the navigation, but I suspect it might just be a lighting adjustment for its position in nav cars.
Otherwise as far as I can tell, the only other module that cares about the navigation system is the instrument cluster. One function is the speed limit thing which you can still set via the Avin. The other function is the distance to the next turn, which I guess won't work anymore (but leaving it enabled shouldn't hurt anything).
Old Fri, Jan-12-2018, 05:40:40 AM   #29
scoopy128
Oh ok thanks reason i ask because when im using my ista if i dont see the navigation in my radios menu it takes like 15 mins to scan my car and read all the modules and it will show a nav error. But sometimes if my nav is working it can finish the scan in just like 2 mins hehe
Old Fri, Jan-12-2018, 11:17:11 AM   #30
If you remove the nav option code, it'll just look for the standard radio instead which will give the same issue.
Discussing Comprehensive Avin Avant 3 Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
