Old Thu, May-18-2017, 03:28:36 AM   #1
jf1000
Reputation: 0 jf1000 is on a distinguished road
Default Steering question
98 m3 convertible 84k miles
Today I started my m3 for the first time since 11/16. I store it inside for the winter with a trickle charger.
The steering seems to have lost some of its power. Almost like non power steering. It does not return to straight after taking turns. I have to manually turn it back to center.
I checked the ps fluid and it is spot on. I have the front hires inflated to 38psi. The belts seem to be fine.
There are no notable noises when turning.
Any ideas?
Jump to top jf1000 is offline   Reply With Quote
Old Sun, May-21-2017, 09:33:47 AM   #2
Hasan Shaikh
Reputation: 0 Hasan Shaikh is on a distinguished road
United Arab Emirates
Default Re: Steering question
How old is the steering fluid? A fluid flush might help.
Also, check your tie rod ends.
Jump to top Hasan Shaikh is offline   Reply With Quote
Old Fri, May-26-2017, 12:16:52 AM   #3
Bmwpower603
I recently just had this problem. But with my girlfriends 06 330xi.
I applied greese to the u joints on the lower steering shaft ( both ends of the shaft )
Fixed the problem. The cars steering feels great now.
No infamous steering wheel squeak in the cabin anymore either!
Hope this helps.
Old Sat, May-27-2017, 03:19:10 AM   #4
///Minivan
Reputation: 0 ///Minivan is on a distinguished road
I had a similar situation about 5 years ago with a different car. Turns out the PS belt had slipped off (thanks to a shoddy job by shop doing unrelated work) rendering me without any power steering. It felt like I was driving a bobsled through sand.
Jump to top ///Minivan is offline   Reply With Quote
Old Wed, Sep-19-2018, 02:49:03 AM   #5
jf1000
Spraying lubricant on the steering column ujoint(located just below the ABS) fixed it.
Thsnjs
Discussing Steering question in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
