Old Tue, Oct-02-2018, 05:57:33 PM   #101
fattycharged
can't even
fattycharged's Avatar
Zimbabwe
Default Re: Comprehensive CSL Intake Thread
Originally Posted by scansp7 View Post
Looking forward to hear about that kit, I know people were also just using the GM map sensor installed between the vacuum line.
Where are you guys mounting the MAP sensor? I don't particularly like the current location of mine
Topo Chico
Old Tue, Oct-02-2018, 05:59:01 PM   #102
EYEHAVEYOU
Simon
EYEHAVEYOU's Avatar
I'll definitely post some feedback once I get it all installed. Just waiting for a stupid intake tube and crankcase vent hose to be back in stock.
Old Tue, Oct-02-2018, 06:00:45 PM   #103
fattycharged
can't even
Zimbabwe
Originally Posted by EYEHAVEYOU View Post
I'll definitely post some feedback once I get it all installed. Just waiting for a stupid intake tube and crankcase vent hose.
I have a catch can instead, and currently eliminated the oil drain on the box, any input on whether this is a bad idea?
Topo Chico
Old Tue, Oct-02-2018, 06:01:46 PM   #104
EYEHAVEYOU
Simon
EYEHAVEYOU's Avatar
No clue tbh, hopefully someone more knowledgeable can chime in
Old Tue, Oct-02-2018, 06:13:21 PM   #105
gabylonfive
g-day
gabylonfive's Avatar
Reputation: 0 gabylonfive is on a distinguished road
I just finished soldering on the new caps and H bridge on my DME, the H bridge is tricky!
I ordered Kassel's kit and can report that it works as advertised. It's a very clever solution and quite tidy once you wire everything up. Be advised there are no instructions with the kit so you'll want to make sure you have everything sorted out before you pull the air rail off and run the leads to your DME.
Overall very straightforward though and the quality/price make it great value.
[OE CSL] [Karbonius] [Supersprint] [Dinan] [Bimmerworld] [Rays Engineering]
[Kassel Performance] [AKG Motorsport] [CSF Radiators] [SPAL] [Turner Motorsport]
[ApexRaceParts] [Rogue Engineering] [Ground Control] [Redish Motorsport] [AutoSolutions]
[KEEPER] - 2004 6MT M3 [Alpine White // Cinnamon]
[DAILY] - 2016 Porsche Cayenne S [e-Hybrid]
[TRACK] - 2001 Trackspec Autosports Spec E46 [#75]
[TRACK] - 2005 Lotus Elise [#318]
ig -- @gabylonfive
Jump to top gabylonfive is offline   Reply With Quote
Old Tue, Oct-02-2018, 06:14:57 PM   #106
gabylonfive
g-day
I would imagine as long as the drain is sealed off properly you should be fine as long as your CC works properly. Since it's past the filter you definitely don't want any air intake from that drain port.
ig -- @gabylonfive
Old Tue, Oct-02-2018, 06:36:04 PM   #107
fattycharged
can't even
Zimbabwe
Default Comprehensive CSL Intake Thread
Agreed, I picked up a used box recently and the drain port fitting was broken, so I chipped it out and currently have some Gorilla tape covering it but I used some on a skiff to cover a small puncture for 6 months with saltwater use and it worked like a charm, so who knows
I havenít run it yet, but need to figure out a more elegant solution before I do.
Topo Chico
Old Wed, Oct-03-2018, 01:14:47 AM   #108
duracellttu
correct, thats the only difference.
TTFS also makes a csl vaccum rail:
http://tuningtechfs.com/ttfs-e46-m3-...nd-map-sensor/
Awesome thanks!
Iím also planning to use for the ECU conversion and MAP sensor.
2005 BMW M3 ZCP - Black/Black 2M Autowerks Full Respray and Restoration: RKP Slicktop Conversion, OE CSL Trunk, JCSL Diffuser
Paul Claudes Custom Tune | Kassel Performance CSL ECU Conversion | Lang Stage Stage 2.5 Head | 288/280 Schrick Cams | CSL Karbonious Airbox | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91 w/ 3 stage clutch
TCK SA 450/500 | Vorshlag Camber Plates | Rogue Engineering ASP, RSM | AKG FCABs, RTABs, SFBs | TMS Sway Bars, Camber Arms, Pullies | Mason Race Strut, Rear X-Brace | AS 30% SSK | SPAL Fan | Redish Reinforcement | Turbo Toys V2 Hub | WPC Treated Rod Bearings
Jump to top duracellttu is online now   Reply With Quote
Old Mon, Oct-08-2018, 12:49:54 AM   #109
arg617
Reputation: 0 arg617 is on a distinguished road
I have been sitting on a Karbonius intake with snorkel (no flap) and would like to get it installed this winter. I can't seem to wrap my head around MAP, MAF, DME, etc. Also the drivability of each path and what's needed for installation.
I was thinking of going with an EPIC Alpha-N tune. From what I understand I'd need a vacuum rail (TTFS most likely). Any drivability concerns? Anything else needed?
Or is a CSL DME the way to go these days? How is that tuned? Can it pass emissions?
Thanks.
Jump to top arg617 is offline   Reply With Quote
Old Sun, Oct-21-2018, 08:21:51 PM   #110
EYEHAVEYOU
Simon
EYEHAVEYOU's Avatar
Anyone have any tips for getting the throttle body boot clamps on? Having a real tough time with them (the clamp thatís closer to engine side)
Discussing Comprehensive CSL Intake Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
