Closed Thread
Old Wed, Aug-14-2013, 08:17:36 PM   #41
m3 hal
Default Re: Evolve Supercharger S54
Sounds good, thanks for sharing these details and the thought process behind them
Jump to top m3 hal is online now
Old Wed, Aug-14-2013, 09:45:43 PM   #42
x Spades x
Reputation: 0 x Spades x is on a distinguished road
Now Sal/Imran, can you make this sound like a CSL (if choosing the CF version... if there is one). Molding the trumpets, etc. OR possible making the kit to it can attach to the current airbox assembly (section containing the air filter). :-)
It would be DOPE to have a supercharged car, that sounds like a CSL!
Jump to top x Spades x is offline
Old Wed, Aug-14-2013, 10:07:35 PM   #43
Shimmy23
Addicted
Shimmy23's Avatar
Reputation: 0 Shimmy23 is on a distinguished road
^this, plus the sound of the supercharger whining and a whoooosh!!!
brandon
Jump to top Shimmy23 is offline
Old Wed, Aug-14-2013, 10:31:07 PM   #44
Frankenstein M3
M3 Unleashed
Frankenstein M3's Avatar
Reputation: 0 Frankenstein M3 is on a distinguished road
Originally Posted by evolve_auto View Post
We are increasing the size of the crank pulley and then re-sizing the rest of the pulleys so that the ancillaries remain at the same speed.
The reason for this is so that we can run a larger supercharger pulley further improving belt traction and life. The larger surface are we have on the supercharger pulley they better it is.
We do not want to be using tiny little pulleys when spinning the blower to it's maximum. It just doesn't work from experience.
The c38 91 is still in its efficiency range up to 14psi on stock crank pulley so maximum efficiency shouldn't be a problem unless your level 2 will supersede 14psi. are you trying to keep secrets here
Running the bigger pulleys all around will result in more boost earlier relative to stock. As long as it is a 8 rib set up there will be no belt slippage even at the 70mm. Anyways I was wondering if you guys increased the alternator diameter too or just crank, water pump, and power-steering ?
Jump to top Frankenstein M3 is offline
Old Wed, Aug-14-2013, 10:43:10 PM   #45
kaiv
SoCal S54 specialist :P
kaiv's Avatar
France
Cooling cooling cooling cooling.... Please make a kit that doesn't overheat when tracked in California
I'll volunteer for testing
E46 ///M325i Touring journal
Jump to top kaiv is offline
Old Wed, Aug-14-2013, 10:47:12 PM   #46
Dave B
M3 collector
Dave B's Avatar
Italy
This thread is awesome. Very informative, especially for someone who has only elementary understanding of this stuff. Definitely solidifies my thinking behind putting a blower on my vert (eventually) despite being more of an NA traditionalist. Between this and Sal's excellence today I'm really loving Evolve right now.
Jump to top Dave B is online now
Old Wed, Aug-14-2013, 10:57:50 PM   #47
jickel180
Fair Enough
jickel180's Avatar
Reputation: 0 jickel180 is on a distinguished road
This, and if you need another hot weather tester in Texas I'm here.
Jump to top jickel180 is online now
Old Wed, Aug-14-2013, 11:08:09 PM   #48
Jonzny
Jonzny's Avatar
Reputation: 0 Jonzny is on a distinguished road
I can run the US prototype for you guys!
Catless Headers | 8.2k Redline | ST Coilovers | Powerflex RTABS & FCABS
Jump to top Jonzny is offline
Old Wed, Aug-14-2013, 11:09:09 PM   #49
flipm3
E46 M3 | E90 M3
flipm3's Avatar
Reputation: 0 flipm3 is on a distinguished road
I shall echo these thoughts. If you need a tester for the cold midwest winters, I am here as well.... ... Or if you need a car to compare data between Stock vs Stepped Header vs CF Airbox + Stepped Header, I can fulfill that too
2004 E46 M3 6MT | Silver Grey . Cloth | My E46 M3 Build Thread
2009 E90 M3 DCT | Melbourne Red . Speed Cloth | My E90 M3 Build Thread
2002 E46 M3 6MT | Jet Black . Black Nappa | My E46 M3 Build Thread
2016 981 Cayman 6MT | White . Black | Coming Soon
POST YOUR DYNO GRAPH HERE: The Official Dyno Thread
Jump to top flipm3 is offline
Old Wed, Aug-14-2013, 11:24:14 PM   #50
m3 hal
That is probably another part of the push for carbon fiber, because it would definitely have poor sound muffling properties. My only concern would be long term durability with boosting on a carbon manifold, but that may be unfounded.
Closed Thread
Discussing Evolve Supercharger S54 in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
