Old Mon, Sep-24-2018, 01:40:06 PM   #11
mossyoaks
mossyoaks's Avatar
Reputation: 0 mossyoaks is on a distinguished road
Default Re: Leaking Clutch Fluid under transmission
Originally Posted by mossyoaks View Post
This ^^
Just replaced the slave & master on my e36/7 Z3 and will install new s/m in my 95 M3 this weekend.
The install on the Z3 is quick because the 2 13mm slave nuts are very easy to reach/remove. Not so on the M3. Super tight fit.
Anyone have a recommendation on the best way to get to that uppermost nut on the slave cylinder?
Jump to top mossyoaks is offline   Reply With Quote
Old Tue, Sep-25-2018, 01:24:15 AM   #12
NolliM3
NolliM3's Avatar
You'll need an extension on that 13mm socket...I think I used a 9" extension...you'll need to feel the nut...since your car is not as tight as the M3, good luck!
Discussing Leaking Clutch Fluid under transmission in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
