Old Wed, Oct-03-2018, 04:32:55 AM   #971
hatuey
hatuey's Avatar
Reputation: 0 hatuey is on a distinguished road
Default Re: The Official E46 M3 Oil Analysis Results Thread
Just to add to the database. Here are the results from the previous owner. Bearings should be done hopefully next week.
Edit: changed it to a jpg so it's not an attachment. Crossing my fingers.
Jump to top hatuey is offline   Reply With Quote
Old Wed, Oct-03-2018, 04:57:33 AM   #972
Texaz3
Yup, need bearings done.
Old Wed, Oct-03-2018, 03:08:45 PM   #973
RedOctober330
RedOctober330's Avatar
Reputation: 0 RedOctober330 is on a distinguished road
Originally Posted by mrgizmo04 View Post
Not a bad report, but I'll keep hammering this point...
I don't understand their commentary on these. The averages they provide in right-most column are based on ~5k mile intervals. Your interval was ~60% of that (3k), so naturally you would expect lower ppms, but your numbers are VERY close to the averages. To me that means, ok/good, but not great, and too early to celebrate. If you keep sending them samples every 1000 miles, numbers will look even better and there won't be anything to worry about, right? Keep things in perspective.
I mean I agree with you to a point. I track the car pretty hard and have nothing from POs about the maintenance history, so I wanted to get some fresh oil in and send what I had to blackstone and see what they found. Not 5,000 for sure, but it’s better than 1,000 miles and I think I wouldn’t bother to send another sample in until 5,000 miles. This was just to give me a starting point; better than the numbers being high and knowing I need to replace them like next week. Better than nothing.
Jump to top RedOctober330 is online now   Reply With Quote
Old Thu, Oct-04-2018, 01:47:01 AM   #974
bran.stum
Reputation: 0 bran.stum is on a distinguished road
Jump to top bran.stum is offline   Reply With Quote
Old Mon, Oct-08-2018, 06:29:56 AM   #975
SL Blak Soldier
Doooorrrifttt
Reputation: 0 SL Blak Soldier is on a distinguished road
This thread needs more reports and actual damage!
Here is my setup. 159k. 2004 (11.03 build) stock rod bearings. Only owned this car for the past 30k miles, not sure how it was driven between 116k-130k but 80k-116k it was babied... I've been driving it fairly hard, but only when warmed up. I had a slight vibration at idle that scared me so i got them done ASAP. (slight vibration went away but not sure if linked)
Replaced with VAC bearings & ARP studs.
23 PPM Copper vs 18 PPM 9.5k miles ago
57 PPM Lead vs 23 PPM 9.5k miles ago
9.5k Service (TBN still looks good)
Oxford Green/Cinnamon 6spd - Garage 54 | Unique Auto Films | 13th Letter | MiniCorsa | Speed District
Jump to top SL Blak Soldier is offline   Reply With Quote
Old Wed, Oct-10-2018, 10:48:06 PM   #976
Fhcrubarb
Fhcrubarb's Avatar
Reputation: 0 Fhcrubarb is on a distinguished road
Thanks for the info
Going forward I would highly recommend 5-6K interval oil changes.
Jump to top Fhcrubarb is online now   Reply With Quote
Old Thu, Oct-11-2018, 12:14:55 AM   #977
L0ADED
L0ADED's Avatar
When did you car get the rod bearing replacement by BMW if it was part of the service action?
Old Fri, Oct-12-2018, 02:40:56 AM   #978
SL Blak Soldier
Doooorrrifttt
Originally Posted by Fhcrubarb View Post
Thanks for the info
With TBN good, why would you recommend a lower interval?
It wasn't apart of that service.
Old Fri, Oct-19-2018, 06:13:27 PM   #979
CrookedCommie
Captain Slow
CrookedCommie's Avatar
Bulgaria
Red Line 50WT Race ~22-25 heat cycles on slicks getting PR's on this sample. Looking good, I'm sticking with this from now on. Left to right we've got Red Line, Red Line, Ravenol, Total, LM (10w-60).
Jump to top CrookedCommie is online now   Reply With Quote
Old Fri, Oct-19-2018, 06:24:06 PM   #980
Call me crazy, but I feel like your lead wear rate isn't fixed-- you're just seeing less at once because of how few miles you're doing between changes.
Discussing The Official E46 M3 Oil Analysis Results Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
