Old Tue, Apr-12-2011, 04:42:56 AM   #21
hencini
Carlos is My Co-Pilot
hencini's Avatar
Default Re: ASC Delete options?
Originally Posted by Roland H View Post
A cookie. I have been running this set up since 2008, my ABS has NEVER failed.
Huh, good to know. Guess I better get on this...
Edit: Oh, and I was kinda serious about the CD93 thing... I know that has something to do with my car's production code on RealOEM, but beyond that I've never really knew much more than that... Is it DME related or just tied to production date or both?
Old Tue, Apr-12-2011, 04:44:44 AM   #22
ASC FTL
it only holds back the M POWAAH
Reputation: 0 ASC FTL has disabled reputation
Where did you hear this? I have never heard of this being true.
I have - BMWs way to try and decrease sudden lift off oversteer by decreasing the engine braking effect or something to that extent. It can still cause you to spin out.
Instead of trying to figure out this ill conceived clap-trap it's best to get rid of it. If you want GOOD traction control, get an e46 Just not in the cards for us e36 owners.
'99 s52 ///M3 s50 mani, JC CAI, JC tune, remus exhaust, ASC delete, xbrace, Eibach Pro springs, Konis, zionsville rad, ZKW hids
Jump to top ASC FTL is offline   Reply With Quote
Old Tue, Apr-12-2011, 04:47:23 AM   #23
ASC FTL
Henci - did you see my post on page 2 (at least for me cause I use default settings!)
Old Tue, Apr-12-2011, 04:50:37 AM   #24
jvit27
TEAM OEM
Reputation: 0 jvit27 is on a distinguished road
Like ASC FTL said, remove the throttle body and put the 98 M roadster elbow in place. Leave actuator untouched.
My ASC light is not illuminated, but it is does not function (can spin the wheels whenever I want). ABS works fine, no light either. Car is basically like a 95 - you'd never know the system was there but it's still easily reversible in 5 mins. No resistors necessary.
Jump to top jvit27 is offline   Reply With Quote
Old Tue, Apr-12-2011, 04:52:52 AM   #25
Roland H
LOLiticks troll
Roland H's Avatar
Reputation: 0 Roland H is on a distinguished road
I asked for a source. The ABS/ASC computer affects the airflow into the engine and controls the brakes, the DME does the rest. The ABS/ASC computer does not control ignition timing on the E36.
Find a source if I'm wrong, but I can't see a logical reason for the ABS/ASC computer to have control over ignition timing.
Jump to top Roland H is offline   Reply With Quote
Old Tue, Apr-12-2011, 04:55:09 AM   #26
ASC FTL
My ASC light came on (personally I got used to seeing it on as i used to turn it off all the time anyway)
It should have for you as well, unless your bulb burned out at the same exact time The only way to keep the ASC light off after this mod is to
1) remove the bulb
2)use black tape
3)reprogram the ecu
Old Tue, Apr-12-2011, 04:57:46 AM   #27
fiveightandten
fiveightandten's Avatar
Either way, when you throw the resistor in, it tricks the ASC into thinking the actuator is nonfunctional, and so the timing wouldn't be affected anyway. If it didn't, and your actuator failed, your motor would explode. BMW wouldn't let the car do that.
Bentley Manual. See attachment. Read the part in italics at the top of the page before you respond that it's talking about AST.
And with regard to the resistor. I was under the impression that it tricks the computer into thinking that it's *there*, as opposed to nonfunctional. The guy who first proposed that just got a multimeter, measured the resistance of the actuator in a position of rest, and shoved the resistor in there in place of the actuator. How does it simulate the actuator being nonfunctional?
Take a look at your VIN.
-Nick
Old Tue, Apr-12-2011, 05:02:20 AM   #28
Roland H
LOLiticks troll
Roland H's Avatar
I would think that if you disable the ASC system with the resistor, it wouldn't touch the timing at all. It would be pretty noticeable if the timing suddenly retarded when my rear wheels began to spin. Also, the light comes on when the system is off or nonfunctional, when you use a resistor, the light comes on. So therefore, I don't view it as much of a risk.
I'm still not convinced the ASC computer actually controls the timing, I think it just tells the DME to retard or advance the timing and the DME does so within safe parameters.
Old Tue, Apr-12-2011, 05:03:50 AM   #29
hencini
hencini's Avatar
Huh. I'll be damned. So what does that have to do with the ASC discussion?
Old Tue, Apr-12-2011, 05:05:37 AM   #30
ASC FTL
Roland we should keep this on the DL, because so far you've been right about everything else
http://www.steerbythrottle.com/hccyo.../E36_ASC+T.pdf
"ignition control" - this document explains very well what the ASC was designed to do.
I don't recall where I read all this originally, but I researched the ASC+T pretty thoroughly before messing with it.
Discussing ASC Delete options? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
