Old Sun, Sep-30-2018, 09:12:16 PM   #1
walid.m3
walid.m3's Avatar
Reputation: 0 walid.m3 is on a distinguished road
Default M3 e36 clunk noise
Hey Guys,
I was wondering if any of you had any issues with clunking noise from the front end. At low speeds (even stationary) when turning left and right I hear like a clunking noise. Even like the slightest movement of the steering wheel I hear it. Even when turning fully left/right it's like multiple clunking noise.
Let me know if it's like a common bushing that needs to be replaced on these e36 m3.
I am running Bilstein pss9 coilovers.
Jump to top walid.m3 is offline   Reply With Quote
Old Sun, Sep-30-2018, 09:19:30 PM   #2
Default Re: M3 e36 clunk noise
Coilovers like the PSS9 require marine grease on the perches or plastic isolators. The springs are metal on metal to the perches and rattle like crazy if you install them dry.
That said, your issue could be any number of issues. Sway bar end links, sway bar bushings, control arms, tie rods, steering giubo, etc etc. How about you help us out and see where the noise is coming from. Otherwise the answer is to fix common issues is to replace everything.
Old Sun, Sep-30-2018, 10:31:36 PM   #3
bluptgm3
Most likely springs (as mentioned above), but could even be dry Guide Supports (bearing in Strut Mount.)
Old Sun, Sep-30-2018, 11:25:13 PM   #4
Dr Ed
Reputation: 0 Dr Ed is on a distinguished road
When you installing the coilovers, did you include the original dust washers underneath the strut mount? I didn’t install it, and it the springs to clunk when turning at low speeds.
Jump to top Dr Ed is offline   Reply With Quote
Discussing M3 e36 clunk noise in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
