Old Sat, Jan-20-2018, 10:07:10 PM   #1
///ALpineVert
Reputation: 0 ///ALpineVert is on a distinguished road
Default Help diagnose rear knocking noise
The sound can be heard at low speeds, not always there. I can’t hear it when the car is cold, I hear it after it’s been driven a bit. It is coming from the right rear.
ETA: CSB and guibo were replaced 1k miles ago.
Can you tell what it is?
Jump to top ///ALpineVert is offline   Reply With Quote
Old Sat, Jan-20-2018, 10:49:41 PM   #2
mrgizmo04
mrgizmo04's Avatar
Default Re: Help diagnose rear knocking noise
To me sounds like maybe loose diff bolts/bushing? Check bolt torque for front bolt especially. What condition are the diff bushings in?
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sat, Jan-20-2018, 11:57:50 PM   #3
///ALpineVert
The rear diff bushing I can see looks ok.
I’ll check the diff bolt tomorrow when I get it off the ground.
Old Sun, Jan-21-2018, 02:30:34 AM   #4
rovert604
rovert604's Avatar
You can easily get to the front diff bolt by lifting the rear right of the car and using a 7mm to pull the one screw holding onto the plastic shield to flex out of your way. Then a 21mm with short extension 1/4 drive torque wrench should be able to get in the front diff bolt. Youíll need it to be 148lbs of torque.
--Trevor in 604--
Vancouver, BC, Canada
Old Mon, Jan-22-2018, 01:02:49 AM   #5
///ALpineVert
So...I went to put the rear up on stands to troubleshoot and went to pre-loosen the wheel lugs. I discovered hat the rear passenger wheel lugs were loose already. So I’m relieved and terrified at the same time. Relieved that tightening the lugs fixed it, but terrified at the thought of what could have happened.
I check them before every autox, did last month. It’s almost like someone loosened them on purpose. Yikes.
Thank you for all of the ideas and help. Dodged a bullet on this one.
Old Mon, Jan-22-2018, 01:28:23 AM   #6
rovert604
rovert604's Avatar
Wow yeah. Thatís one thing I always take for granted. Itís happened once to me and all wheels were loose. I caught it within two blocks of the sound happening and retightened.
--Trevor in 604--
Discussing Help diagnose rear knocking noise in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
