Old Sun, May-29-2016, 08:16:40 PM   #31
usedunderwear
Reputation: 0 usedunderwear is on a distinguished road
Default Re: Joe's E36 M3 Coupe Journal
Great work!!
Jump to top usedunderwear is offline   Reply With Quote
Old Tue, May-31-2016, 02:13:57 AM   #32
JitteryJoe
Front wishbones powder coated and new ball joints pressed in. Kind of a bear to get the wishbone in the press with the correct orientation and support.
The long shaft of the center ball joint is problematic. Used a really big 3/4 drive socket for support.
Took my old calipers and refreshed.
A bit of a rusty & worn mess when torn down
Sandblasted & powder coat. New seals, stainless pistons & pins with brass guides
Sometimes the right tools just makes it easier
All done. Getting the pistons in the caliper is a PITA. Not sure I'd spend the time again. They do look purdy though. Not absolutely sold on the color but I wanted something that would show off behind the wheels without going to red.
Old Sun, Jul-10-2016, 08:26:14 PM   #33
JitteryJoe
I recently came to the conclusion that I'm not going to get this finished by September which was my goal. I'm just too slow getting the work done and too many to-do items left on the list. Oh well.
I got the rear trailing arm assembly built and installed. I mounted the half shafts first along with the parking brake hardware and cable. One half shaft went into the new hub fairly easily. The other was very stubborn so I'm glad I did it where I had some leverage and could apply some persuasion. Getting the assembly mounted was a bit of a pain with the axle, trailing arm and parking brake cable all trying to swing in different directions but, with some help from another person, managed to get it bolted up.
Once the trailing arm assembly and axles were in, I jacked up the diff to set it in place. Had to tilt it almost vertical to clear the lower subframe member and get it into the subframe mounting hole. This was a pain to do by myself but right now I have it sitting in place on a jack waiting to be bolted in. I'm not bolting in quite yet as it looks like I need to torque the inner suspension bolts first (see picture). I don't think I can get to these with a torque wrench with the diff pulled forward into its mount. The problem is that I believe these need to be preloaded before torqueing so I'm a bit between a rock and a hard place. I'm going to go ahead and install the new springs and shocks and see if I can figure out the preload problem. I left all the bushing bolts loosely tightened (both inner and outer) figuring I'd need to do this.
Old Sun, Jul-10-2016, 08:49:07 PM   #34
ftc3
Reputation: 0 ftc3 is on a distinguished road
Great progress! I'm with you; I'd rather go slow and get things just as I want them than rush and potentially skip something I would regret later.
My journal
Dinan Intake | Dinan TBs | Schrick 280/272 | SSV1| SS Res Sec 2 | Dinan Exhaust | Koni Yellow | Dinan Springs | TTFS Tune | 356WHP
Jump to top ftc3 is online now   Reply With Quote
Old Mon, Jul-11-2016, 10:58:40 PM   #35
JitteryJoe
Just went through your E46 journal. Pretty awesome.
Old Sun, Jul-24-2016, 04:17:30 PM   #36
JitteryJoe
Managed to get the brakes with new disks installed along with the rear suspension. Still trying to figure out how I preload the suspension before final torqueing a few of the bolts. Cleaned up the area the best I could. Replaced the plastic wheel-well liners.
Starting to look good.
Picked up the disks on sale from Turner. Suspension from Bimmerworld.
Heard good things about Porterfield pads. Got them on sale from Pelican.
Old Sun, Jul-24-2016, 08:30:06 PM   #37
usedunderwear
Very clean!! Good job
Old Sun, Jul-31-2016, 04:19:22 PM   #38
englishtom1596q
englishtom1596q's Avatar
Awesome work! I'm actually doing the same suspension rebuild right now! Do you have the part number for the right rear wheel liner? The one that sits behind the wheel? Tried searching the numbers printed on it but came up empty handed
Old Mon, Aug-01-2016, 02:52:11 AM   #39
Evtron
Evtron's Avatar
Reputation: 0 Evtron is on a distinguished road
I love build threads like this. Everything looks perfect. Which brake lines are those?
E36 M3 Sedan Journal
Jump to top Evtron is offline   Reply With Quote
Old Mon, Aug-01-2016, 04:15:29 AM   #40
JitteryJoe
I believe your are looking for 16132227852.
Good luck with your suspension rebuild!
Discussing Joe's E36 M3 Coupe Journal in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
