Old Fri, Aug-12-2016, 02:10:37 PM   #61
ThunderMoose
Default Re: paffy GTS4 build
Originally Posted by bigjae1976 View Post
Sounds like you got it fixed. This is a great thread...keep these updates coming!
I've always wondered if post weld heat treating would improve the stiffening function of the cage. Yeah, I'm sure there is added stress and twist when you introduce a lot of heat to a fixed tube welding on more tubes which sounds like what you may have experienced. While the cage does add stiffness I can imagine the structure not binding at all...wouldn't that affect handling? Just like a suspension, you don't want binding at rest.
I'll ask some people at work.
Post weld heat treatment just relieves the stresses in the welds to reduce the likelihood of cracking. I don't think it would help to stiffen the frame.
#67 2017 NASA TX TT3 Champion
Old Fri, Aug-12-2016, 02:37:42 PM   #62
bigjae1976
I believe PWHT actually weakens the weld and would not add stiffness. But it should relieve some of the stress (torsional???).
But it's kind of like a sway bar...you want the bar to be unbound with no stress when the car is at rest. If you weld in a cage and it had some stress in the tubes...I wonder if PWHT could improve the handling characteristics like going from an bound up sway bay to a properly setup bar.
I'm considering it...certainly won't hurt.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Fri, Aug-12-2016, 05:04:39 PM   #63
paffy
Reputation: 0 paffy is on a distinguished road
Czech_Republic
I can get it in the correct position with my own body weight. So there will be one cross member that will be in constant compression of 2000N, I can live with that.
I've done some research on cracking, HAZ, PWTH etc. and settled on using ER70S2 welding rods. The mixture or normalized 4130 and the E70 metal should give a good balance of strength and ductility right off the bat.
http://www.msstuning.com/ - serving your MSS5x flashing needs
2014 BMWCCA NY autox E class champion
My GTS4 build journal - http://www.m3forum.net/m3forum/showthread.php?t=551613
Jump to top paffy is offline   Reply With Quote
Old Fri, Aug-12-2016, 06:08:37 PM   #64
Wow kudos man! Thanks for documenting it.
_
Old Sat, Aug-13-2016, 12:37:35 AM   #65
paffy
Czech_Republic
Wasted whole afternoon adjusting the rear halfcage. All aligned with a crossbar in place holding the proper shape.
Sunroof opening is useful for access to top of the down-tubes welds ! Maybe I won't have to cut the floor after all.
Old Mon, Aug-15-2016, 09:07:06 PM   #66
paffy
Czech_Republic
4 hours
Welding the front for real this time:
Split it to get access to top and other hidden welds:
Old Tue, Aug-16-2016, 12:34:13 AM   #67
bigjae1976
Dang...isn't it hot as hell in the northeast right now? You've got me really wanting to get welding but it's way to f@!#ing hot in KS right now.
Old Tue, Aug-16-2016, 12:46:14 AM   #68
paffy
Czech_Republic
It's only 95 today
I did get an awesome burn on my chest from tackwelded everything shirtless though.
Old Tue, Aug-16-2016, 01:21:29 PM   #69
NotUrAvgM
Reputation: 0 NotUrAvgM is on a distinguished road
Really inspiring work; finished product is going to be great! Cant believe you're doing this in your driveway. What was your former job with the aircraft design?
Learned that lesson on bead #1 welding RTAB pocket reinforcements upside down on my car in short sleeves Gravity is an SOB.
-Matt
[2004 330xi/6] Orient/Natural :: 147k :: ZSP :: ZPP :: ZCW
[1998 M3/4/5] Cosmos/Black :: 126k ::TCKline D/A (500/600) :: GC plates :: RD Sways :: GC Rear Arms :: BW FCAB :: BW RTAB :: AKG Subframe :: 3.64 Diffsonline :: TMS Pulleys :: AA + Borla :: XBrace :: AS SSK :: ZHP Rack :: M50 :: DTC60 :: Direzza ZIII :: Safety Equipment
[2016 Yamaha R3] White/Red
Past:
[1995 M3] Avus/Dove :: 242k :: S52 OBDI :: M50 manifold :: 3.5" HFM :: Turner Chip :: XBrace :: SS Lines :: Turner RTABS :: Vogtland CS :: Bilstein Sport
[1999 M3] Cosmos/Black :: 87k :: TCKline S/A (400/500) :: Turner plates :: UUC Front Sway :: PF RTABs :: AA Intake :: Borla :: XBrace :: TRM C2s :: CL RC6E :: Direzza ZII :: Safety Equipment
[1993 325is] Brilliant/Black :: 139k :: Bilstein sports :: Eibach sways and springs :: Dinan camber plates and chip :: Borla :: LSD
[1983 320i] Safari/Brownish :: 242k :: homebrew CAI :: some rust :: multicolor body panels
Jump to top NotUrAvgM is offline   Reply With Quote
Old Fri, Aug-19-2016, 12:42:03 AM   #70
paffy
Czech_Republic
5 hours
All welds complete 360 !
Mounting plates:
Discussing paffy GTS4 build in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
