Old Thu, Jan-10-2013, 01:49:05 PM   #1
waldron80
waldron80's Avatar
Reputation: 0 waldron80 is on a distinguished road
Default Blackstone Oil Report - Rod Bearings? Is this the end? Thoughts?
UPDATE 1-19-13: For my follow-up report see post #15
UPDATE 4-16-13: For my follow-up report see post #16
UPDATE 8-20-13: Follow-up report on post #22
So I finally grabbed my year old sample of oil off the shelf and sent it to Blackstone Labs. The anxiety of getting my report was near the anxiety I had before my daughter was born!
Anyway, got the report back with high iron, copper, and lead at 22,16 and 24 ppm respectively. Is this low, med, high, super high? Is this the END!? This is part per million right? Should I be taking my car to the shop this afternoon?
Can fuel additives do this? Could this be anything else?
I have a May 2003 build which did have the recall performed by the first owner.
This report was done at 87k and I'm currently at 105k miles and will be pulling another sample as soon as I get my filter and oil from TMS. It will have about 10k on this oil change as well.
Let me know if you guys want any other info.
Yes I'm using Castrol 10W60.
Any thoughts?
Report below:
My RTAB Experience - Don't do what I did....
Often requested Tire Size Calculator -- My 3.5mm AUX install -- My home grown Maintenance Spreadsheet
Jump to top waldron80 is offline   Reply With Quote
Old Thu, Jan-10-2013, 02:12:44 PM   #2
niart906
Reputation: 0 niart906 is on a distinguished road
Default Re: Blackstone Oil Report - Rod Bearings? Is this the end? Thoughts?
I would do another analysis just to be sure, but it seems to me that your due for a rod bearing job. Iron, copper and lead are all double or more than the universal average. If it was slightly elevated I'd say that it could be a fluke. But considering how high those levels are, you may want to prepare your wallet for the worst.
Current Car:
2013 F30 335i Estoril Blau II/Black
Previous:
2006 E60 M5 Silver-Gray/Indy Red
2003 E46 M3 Jet Black/Cinnamon
Jump to top niart906 is offline   Reply With Quote
Old Thu, Jan-10-2013, 02:14:42 PM   #3
Originally Posted by niart906 View Post
I would do another analysis just to be sure, but it seems to be that your due for a rod bearing job. Iron, copper and lead are all double or more than the universal average. If it was slightly elevated I'd say that it could be a fluke. But considering how high those levels are, you may want to prepare your wallet for the worst.
The universal averages are based on a much shorter interval though, aren't they? (right around 5k if i'm not mistaken). In theory, if his interval matched the universal average interval, his copper and iron numbers would be right around average, no?
Granted his other numbers are considerably better than the averages, and his lead numbers are high no matter how you slice it. So yeah, he probably does need new bearings. I really should send a sample one of these days.
Old Thu, Jan-10-2013, 02:14:58 PM   #4
lucad2
lucad2's Avatar
Reputation: 0 lucad2 is on a distinguished road
Damn I need to do one.
"M" The most powerful letter in the world
Originally Posted by wyskass View Post
If a new owner showed up at some meet or started talking to you in the parking lot, would you tell him to STFU and suggest he read a book?
Jump to top lucad2 is offline   Reply With Quote
Old Thu, Jan-10-2013, 02:20:12 PM   #5
niart906
Maybe slightly elevated, but more than double the average?
5k on our oil seems overkill, I typically go 7,500 but have considered doing 10k. I'm not sure what Blackstone uses for their averages.
At the very least, those metal levels would be enough to convince me to lower the interval and get another sample tested.
Current Car:
Previous:
Old Thu, Jan-10-2013, 02:38:45 PM   #6
RedM3/4
I'd call Blackstone and ask some of the questions about universal avergages, but lead is 6x any way you cut it, not good. Only question is, how did you take your old sample? Was it hot/fresh/ unstratified when you gathered it? If so, pretty sure it's time for rod bearings. If you took it from an old quart or whole drain load that had sat, and didn't stir it well, still probably bad unless you scraped the bottom of the container and picked up extra metal, but this could be a variable.
As to getting to the shop, if you don't hear a low-end thunk, it isn't likely to come apart any minute, but I'd drive it moderately and stay below, pick a number, say 4500 rpm, and make sure you don't lug it, get up to close to 3k rpm before shifting to next higher gear. But I'd not drive it until I got a clunk either, more risk (still not a lot) of crank wear. So if you can get your existing sample sent (maybe even get it from the filter area with a syringe - may have a bit more insolubles but shouldn't affect other numbers if taken hot/right after shutdown) and confirm these numbers, I'd do that pronto and go out for bids and schedule it if the report comes back as I expect it will.
ADS
Old Thu, Jan-10-2013, 06:34:51 PM   #7
ML///M3
Sunday Drive NYC
ML///M3's Avatar
Reputation: 0 ML///M3 is on a distinguished road
Where was the old oil stored? Could it be that the container had remnants of other oil from another car?
2005 /// M3 Coupe ZCP - Road & Track | BMWCCA Instructor
Jump to top ML///M3 is offline   Reply With Quote
Old Thu, Jan-10-2013, 06:55:55 PM   #8
waldron80
waldron80's Avatar
It was stored in the container they provided. I asked before I sent the sample if that was an issue and they said is was not.
Old Sat, Jan-12-2013, 04:59:05 PM   #9
nathanday
nathanday's Avatar
Reputation: 0 nathanday is on a distinguished road
I just got my Blackstone report back and I believe I am F@#%ed. My lead Content is at 117, which they said might be because of race gas (which, since I just bought the car, I cannot attest) My car seems to run fine, although I've never driven another one. I think the car was well abused, judging from the steering wheels and 4 curbed tires and obvious paintwork despite clean Carfax and a filthy liar of a Dealer in D.C. called Bob's Motors. I'm ranting a little, forgive me. here's my report: sob...
J. Nathan Day
Austin, TX
'04 E46 M3
Jump to top nathanday is offline   Reply With Quote
Old Sat, Jan-12-2013, 06:05:59 PM   #10
///NotEvnMyBDay
///NotEvnMyBDay's Avatar
Reputation: 0 ///NotEvnMyBDay is on a distinguished road
WOW... I would get that checked out quick. Blackstone test is in my near future.
2002 E46 M3 - CB on Imola
1987 635csi - Black on Natur
1987 635csi - Black on Lotusweiss
Jump to top ///NotEvnMyBDay is online now   Reply With Quote
bearing, blackstone, oil, recall, rod
Discussing Blackstone Oil Report - Rod Bearings? Is this the end? Thoughts? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
