Old Mon, Sep-06-2010, 11:49:54 PM   #1
delirium45
Bottom Feeder
Reputation: 0 delirium45 is on a distinguished road
Default DIY: Fix stripped drain bung for oil pan
went to put the oil drain plug back in and it just spun... stripped the darn thing... any suggested fixes other than rethread and/or new bigger bolt?
_ Garrett
2011 Rocky Mountain Region GTS4 champion & "Rookie of the Year"
2012 Rocky Mountain Region GTS3 champion
2013 National GTS3 - 4th place
Thanks Sponsors: SCR Performance
Jump to top delirium45 is offline   Reply With Quote
Old Wed, Sep-08-2010, 06:51:07 AM   #2
Tonester
Reputation: 0 Tonester is an unknown quantity at this point
Viet Nam
Thats your only choice at this point really.
I actually have a tool kit especially for redrilling/tapping a stripped out oil pan... drilling/tapping is extremely important since it has to be perfect straight so the bolt can seal against the bottom of the pan.
Jump to top Tonester is offline   Reply With Quote
Old Fri, Sep-10-2010, 09:20:59 PM   #3
delirium45
Bottom Feeder
okay, so, for those that have done this.
i decided to go with a slightly larger sized bolt, i went to standard bolt size of 1/2 inch, which when compared to the 12mm metric bolt from BMW, the 1/2 inch bolt is 12.7mm... large enough to allow me to cut fresh threads, but small enough that i don't have to worry about weakening the pan or if i wanted/needed to later install a helicoil/timesert, i would still have enough material to do so.
i sourced some 1/2-20 in 1/2 inch length from Fastenal (they have local stores in most cities as well as online) because the hardware stores only carried course-thread (1/2-13) and you really want fine-thread for this job.
i chose a stainless steal bolt, but you have some options from Fastenal.
http://www.fastenal.com/web/products...0172314&ucst=t
after cleaning the drain hole in the pan, i proceeded to cut some new threads (be sure to get your tap square with the pan as the bolt will need to sit absolutely flush with the pan to seal properly.
i was worried about the chips from cutting getting into the pan, but i was very happily surprised to find that as i started cutting oil that was waiting just around the hole on the inside started running down the tap, carrying with it the chips.
after a full depth cut of the threads i poured some fresh motor oil in the filler hole on top of the engine... this drained down and carried with it some remaining chips.
after plugging the hole with my finger and releasing it (to build up a pool inside the pan) and getting nothing but clean oil out after a few tries i called it good and cleaned up the threads with a rag.
other nice thing about the 1/2 inch bolt size is that the OEM copper crush washer fits, snug, but it fits. put the new 1/2-20 bolt (with copper washer) in and hand tightened all the way up to the washer.
i was very tentative to tighten the new bolt so i only tightened it with the wrench a little.
started filling the engine with oil and every other Liter i checked the bolt... on my second check i noticed a little wetness around the washer... so i gave another 1/8 turn on the bolt, cleaned up the bolt and continued filling.
checked again and it looked good, time to start the car... oil pressure came up (took longer than normal since more than normal oil had drained out since the car had been sitting (open pan) for a few days) and i checked under the car as it idled... no leaks after two mins of idling... good sign. shut it off.
went back under only minor wetness, could be from oil getting warm and thinning. wiped clean only.
checked oil level since more than normal drained out, thought it might not be up to level... was on bottom dip-stick notch only, added 100mL.
car sat for 4-5 hours, checked before going to bed and slight moisture again... gave another 1/8 turn w/ wrench, now it felt like it was getting tight... i felt good about this... cleaned up bolt and went to bed.
in the morning checked it out and i is bone dry still... will get the car back on the ground and road test it this evening.
_ Garrett
Old Fri, Oct-22-2010, 04:30:23 AM   #4
1ch1ban
Reputation: 0 1ch1ban is on a distinguished road
thank you... good post. i had the same thing on mine... i didn't do it, the previous owner had it this way... it spins and does not come to a dead stop... but it's not leaking oil and i have been driving several thousands miles... i will do this on my next oil change.
Jump to top 1ch1ban is offline   Reply With Quote
Old Fri, Oct-22-2010, 05:55:27 AM   #5
delirium45
Bottom Feeder
good luck !
this is still working just fine for me.
_ Garrett
Old Wed, Aug-17-2011, 08:59:57 AM   #6
1ch1ban
Default Re: DIY: Fix stripped drain bung for oil pan
hey there. now the car is due for oil change and i am thinking about this but i am worried about messing up on cutting new thread. are there any tips you can provide?
do you just align it with the oil pan and just start screwing it in? is there anything you can use to make sure it's aligned in a straight line?
the car hasn't lost any oil at all so actually the "fixing" now becomes a risk. ahhh what to do?
new oil pan looks expensive... couple hundreds dollars...
Old Wed, Aug-17-2011, 01:24:43 PM   #7
delirium45
Bottom Feeder
the tap is pretty easy to square up, i just did my best to eyeball it and i got it just fine.
i agree it's a risk, so you'll need to consider pros/cons for sure.
and a new pan isn't just the part, there is a lot to of disassembly to get it off.
_ Garrett
Old Sat, Nov-17-2012, 08:00:26 PM   #8
jyi
jyi's Avatar
Reputation: 0 jyi is on a distinguished road
This just happened to me. Went to put the drain plug back in and it kept spinning.
I get how to fix this via delirium's post but my problem is this:
The drain bolt is stuck in the drain bung and I can't get it out.
When I try to back it out, it just keeps spinning in place.
I tried to grip it with a vice grip to PULL it out but that didn't work.
What are my options to get the bolt out to tap new threads?
Jump to top jyi is offline   Reply With Quote
Old Sat, Nov-17-2012, 08:17:36 PM   #9
delirium45
Bottom Feeder
if this is the stock bolt, i would get a slightly larger hex/allen wrench and 'tap' that into the hex hole with a hammer so that it is pressure fit.
while applying downward angular pressure, turn the bolt to loosen.
this is how i got it out of a friend's car that was in this situation.
if that doesn't work i would go back to your vice grip option and keep turning to loosen.
_ Garrett
Old Sat, Nov-17-2012, 08:24:45 PM   #10
jyi
jyi's Avatar
It's the aftermarket hex cap bolt magnetic drain plug (17mm hex head).
Looks something LIKE this..
But the thread diameter and pitch are all the same spec to OEM drain plug.
bung, diy, drain, fix, oil, pan, stripped
Discussing DIY: Fix stripped drain bung for oil pan in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
