Old Tue, Mar-29-2011, 04:02:07 PM   #31
warclok
Reputation: 0 warclok is on a distinguished road
Default Re: Oil Leak and it's not the CPV
Originally Posted by BimminLSB///M3 View Post
I am very very glad to hear that this thread helped someone else. I knew I couldn't be the only one with this problem. Congrats on the cheap fix!
Jump to top warclok is offline   Reply With Quote
Old Tue, Mar-29-2011, 04:09:51 PM   #32
hogger453
hogger453's Avatar
Reputation: 0 hogger453 is on a distinguished road
Bulgaria
Glad it all worked out for you and thank you for posting this.
Definitly helpful.
Two possibilities exist:
Either we are alone in the universe or we are not.
Both are equally terrifying.
Arthur C. Clarke
Jump to top hogger453 is offline   Reply With Quote
Old Sat, Aug-15-2015, 06:02:11 AM   #33
ScratcHm3
Reputation: 0 ScratcHm3 is on a distinguished road
Sweden
Same problem in Sweden.
Thanks for this post
Regards,
Jonas
http://rejsa.nu/forum/viewtopic.php?t=91393
Jump to top ScratcHm3 is offline   Reply With Quote
Old Sat, Aug-15-2015, 12:20:33 PM   #34
Amadeus
Stationary Action
Amadeus's Avatar
Reputation: 0 Amadeus is on a distinguished road
I basically had this exact same problem. When I first got my car, oil started leaking. Replaced the CPV o-ring but did not stop the oil. Being a noob, I took it to a dealer who diagnosed it as a $5000 head gasket repair. The magnitude of that number made me do my own research. Ended up being the exact same bolt as the OP, the timing guide bolt. Took out the water pump and replaced it myself for maybe like 70$.
Ever since then, I do everything myself. Even when it requires new tools and a ton of learning. It absolutely appalls me how these dealerships rob people of their money. Can't imagine how many helpless victims gave in and spent 5k on this common type of leak.
Jump to top Amadeus is offline   Reply With Quote
Old Sat, Sep-26-2015, 02:27:46 AM   #35
///M3 NA
Reputation: 0 ///M3 NA is on a distinguished road
I have similar looking oil leak. Replaced the bolt above with a new washer, replaced the Chain tensioner washer, still leaking from somewhere else.
Evolve
Evolve Eventuri
AutoSolutions SSK 30%
RE Transmission Mounts
CDV Delete
Intravee II
Jump to top ///M3 NA is offline   Reply With Quote
cpv, leak, oil
Discussing Oil Leak and it's not the CPV in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
