Old Tue, Mar-30-2010, 04:14:48 PM   #1
playinJ30
Reputation: 0 playinJ30 is on a distinguished road
Default Yellow Oil level Light comes on but oil level is fine... sensor?
Just want to verify that the problem is most likely the sensor... and if so, is this an easy install? Most sensors are located at bottom of the oil pan. Stealership quoted me 400+ to change the sensor (also quoted me 200 bucks to change the microfilter lol)...
The oil has been checked via dipstick and the oil level is not low. The oil was changed in May 09 and the car has less than 6000 miles since then... probably closer to 3000-4000.
I'm pretty handy and can do this myself if I've got a DIY in front of me, but I don't want to start replacing things if I'm not certain that the sensor is the problem. Any help or link to the pertinent thread would be great.
Thanks!
Jump to top playinJ30 is offline   Reply With Quote
Old Tue, Mar-30-2010, 05:23:48 PM   #2
M.Williams
Reputation: 0 M.Williams is on a distinguished road
I had the same issue and replaced the sensor and it fixed it. It is EASY to swap out during an oil change.....just 3 bolts to remove. I got the part from Tischer.....can't remember price but it is around $160 or I think.
Current - 01 LSB M3
Past - 95 M3 GTS-3 racecar
M3's are meant to be driven, everywhere....
Jump to top M.Williams is online now   Reply With Quote
Old Tue, Mar-30-2010, 05:43:32 PM   #3
azndrunk74
Reputation: 0 azndrunk74 is on a distinguished road
Taiwan
yup it's your sensor. i just replaced mine..very easy 15 minute fix. just do it during your next oil change.
LSB|Cinnamon
Jump to top azndrunk74 is offline   Reply With Quote
Old Tue, Mar-30-2010, 06:54:56 PM   #4
deilenberger
deilenberger's Avatar
That's 3 bolts to exchange AFTER you remove the 12 or so one-time-use bolts that hold the big aluminum reinforcing plate on the bottom of the car. This is much easier to do on a lift..
Old Sun, Apr-04-2010, 02:12:10 AM   #5
02icarus
bmw aficionado
Reputation: 0 02icarus is on a distinguished road
i just did this and still get yellow light. pissing me off. bought oem equivalent from ebay for $70. never again.
i kept adding oil because god damn piece of crap dipstick is impossible to see oil level.
do yourself a favor and buY OEM SENSOR.
Jump to top 02icarus is offline   Reply With Quote
Old Sun, Apr-04-2010, 03:40:41 AM   #6
MTK Kommander
MTK Kommander's Avatar
Reputation: 0 MTK Kommander is on a distinguished road
i just did this to my M a couple weeks ago during an oil change.. easiest fix ive done so far..
Jump to top MTK Kommander is offline   Reply With Quote
Old Sun, Apr-04-2010, 05:46:12 AM   #7
gohan
Death Dealer
gohan's Avatar
Reputation: 0 gohan is on a distinguished road
China
can someone post a picture of its location??
Current:
2007 Laguna Blue Pearl S2000
EX GFs:
2011 Mercedes E350 4matic
2002 BMW M3 6speed
2003 Audi A4 5speed
2001 Honda Prelude 5speed
SOLD
Ground Control Street/School (440/550), TMS Subframe re-enforcement (performed by TKX), TMS SS Brake lines, BMC filter, CDV delete, SSR Comps 18x9.5/Yokohama ADVAN Neova AD08 , PF RTAB, Dice iPOD kit, Audi grocery hangers, Vorshlag 90mm Stud Kit, ZHP shiftknob, CSL trunk, diffuser and stuff...
Dearly Missed: http://img.photobucket.com/albums/v1...4/groupsex.jpg
Jump to top gohan is offline   Reply With Quote
Old Fri, Apr-23-2010, 01:22:58 AM   #8
MTK Kommander
remove that big plate under the car, theres like 8 or 10 16mm bolts, u will see it directly on the bottom of the oil pan.. held in by screws and its got a plug.. drain the oil, unplug it, unscrew it, put the new one up there, screw it in, plug it in, replace big plate, proceed with the rest of your normal oil change. done.. very easy.. makes it easier if you have an impact gun to remove that big plate.. doing it by hand wouldnt be fun
Old Fri, Apr-23-2010, 12:05:56 PM   #9
M302_IMOLA
"Just Six"
M302_IMOLA's Avatar
Reputation: 0 M302_IMOLA is on a distinguished road
What do you mean by "one-time-use bolts"? Do you mean these bolts aren't reuseable?
02' IR/IR
Current Mods: Painted front reflectors, matte black fender gills, carbon fiber roundels, Depo smoked corners, 19" Ruff Racing wheels wrapped in Hankook Ventus V12's (245/35F & 275/30R), Status Gruppe coilovers (7K/8K), RE RSM's, Powerflex RTAB's & FCAB's, DICE, CSL Rep Diffuser, CF Hamann Rep Lip, Magnaflow exhaust, Ebay headers, Streamline filter, Afe elbow, RPI scoops, ZHP knob, and EE LED tails.
WTB: OEM Front strut bar, Evolve stage II tune, 4.10's, and CF CSL rep Bootlid
Jump to top M302_IMOLA is offline   Reply With Quote
Old Fri, Apr-23-2010, 12:22:48 PM   #10
It comes on before the oil is at the "min" line, are you sure it's actually not working? As in, you get the oil level to just below "max" and it still comes on?
lol, what issue could you have with the OEM dipstick? Seems perfectly good to me
fine, level, light, oil, sensor, yellow
Discussing Yellow Oil level Light comes on but oil level is fine... sensor? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
