Old Tue, Apr-13-2010, 05:32:10 PM   #31
OahuMPower
:FACEPALM:
OahuMPower's Avatar
Originally Posted by Edgy View Post
Nice thread Nick. Any tips on a detailed DIY for manual trans fluid change? I can only find E36 auto on bimmerdiy for some reason.
open fill plug first..
open drain plug
drain fluid
insert drain plug
fill using pump up to the fill plug
insert fill plug
DONE
Old Tue, Apr-13-2010, 06:04:50 PM   #32
Edgy
Constantly Learning M3 and M5 Owner
Edgy's Avatar
Reputation: 0 Edgy is on a distinguished road
Yup Oahu it sounds easy -- found Ron Stygar's DIY: http://www.unofficialbmw.com/e36/dri...ion_fluid.html
BLUE HEAVEN:
Interlagos 2006 M3, AutoLogic tune, K&N CAI, Agency Power midpipes and exhaust, Fortune Auto coilovers, ///M Pedal Kit, UUC SSK. MRegistry listing here
Le Mans 2002 M5, Black/Titanium, Rogue SSK, Dinan exhaust, PSS9 coilovers, Conforti/Shark tune. MRegistry listing here
Jump to top Edgy is offline   Reply With Quote
Old Tue, Apr-13-2010, 07:15:29 PM   #33
fiveightandten
fiveightandten's Avatar
Originally Posted by M3n00b View Post
I have a question on coolant. When my radiator exploded last time, I only had about 1/2 gallon of unmixed BMW coolant on hand. I filled the rest with distilled water and two bottles of water wetter. Anyone know what temp this mix will start to freeze at? I live in CA and coldest weather I'm ever in is the high teens. Thanks.
You can buy a cheap hydrometer at any auto parts store. That will give you a (relatively) quantitative value on the freezing point of the mixture you have in there.
It's a device filled with little balls that float (or sink) based on the density (or maybe it's the specific gravity) of the coolant mixture. You just suck a little fluid up out of the expansion tank and look at the little balls to see how many are floating.
-Nick
Old Tue, Apr-13-2010, 08:45:20 PM   #34
M3n00b
M3n00b's Avatar
North Korea
Cool. Thanks I'll have to buy a hydrometer and play with it's balls.
Old Tue, Apr-13-2010, 08:47:33 PM   #35
Xiphos
///Moneypit
Xiphos's Avatar
Reputation: 0 Xiphos is on a distinguished road
You make it sound so dirty...
Mine doesn't have balls, it just has a shaft that pivots
Brendan
"Speed has never killed anyone, suddenly becoming stationary... That's what gets you." -Clarkson
E36 M3 DIY Page - Bimmerforums
Jump to top Xiphos is offline   Reply With Quote
Old Tue, Apr-13-2010, 11:58:36 PM   #36
Roguls
Reputation: 0 Roguls is on a distinguished road
A couple of things to add from my experience:
1. Redline MTL is way better than D4 ATF in the 5 speed. Only time the D4 was "better" was in the winter, when it was extremely cold (it flows better in the cold than the MTL). When warm, or when it is not cold outside, the MTL provides for far smoother shifting.
2. In the diff, both the 75w90 and 75w140 should flow the same at startup - the first number is the winter (hence "w") number, which signifies its viscosity when cold. The 140 is heavier duty - it is stock in the e46 M - and protects at higher temps than the 90. Again, though, Redline is the way to go.
Great post.
Roguls
New York
Jump to top Roguls is offline   Reply With Quote
Old Wed, Apr-14-2010, 03:10:12 PM   #37
M3n00b
M3n00b's Avatar
North Korea
So which one is better. The shaft or the balls?
Old Fri, Jun-25-2010, 03:18:47 PM   #38
Diesel///M3
Oh no you d'nt!
Diesel///M3's Avatar
Reputation: 0 Diesel///M3 has disabled reputation
Super quick question regarding Redline diff fluid: 75W140 or 75W140NS? I think the first one, is that correct? Thanks.
"Its not who we are underneath, but what we do that defines us."
-Jay
Upgrades: AA Gen III, AA track pipe, AA tune, H&R Sports, blown Bilsteins, TMS aluminum RSMs, UUC tranny mounts(red), UUC sways, TMS RTABs, M50, CAI, 10mm front spacers, X-brace, Brembo/Hawk, SS brake lines, ltw flywheel/JB clutch, CDV delete, Alpine HU
Coming soon: Powerflex subframe bushings, RE RSMs, UUC RTABS, Koni's, AA diff support bracket, new diff mounts, AA 3.5" CAI, Euro 3.5" HFM, Bimmerworld 3.5'-3" elbow, UUC SSK/DSSR, 140a alternator, 6000K HID heads and fogs...
Jump to top Diesel///M3 is offline   Reply With Quote
Old Fri, Jun-25-2010, 03:45:41 PM   #39
Blanchimont
License Revoked
Blanchimont's Avatar
Reputation: 0 Blanchimont is on a distinguished road
yes 75W140 (the NS does not contain the limited slip friction-modifiers as per Turner's site and Redline's site)
Jump to top Blanchimont is offline   Reply With Quote
Old Fri, Jun-25-2010, 07:32:37 PM   #40
Diesel///M3
Oh no you d'nt!
I thought so but just wanted to confirm. Thanks a bunch!
-Jay
brake, coolant, diff, faq, fluid, informational, oil, steering, thread, tranny
Discussing Informational thread: FLUID FAQ (Oil, Diff, Tranny, Coolant, Brake, Steering) in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
